Technical What are you using for generator or alternator mounts sbc in '35-'36 Ford
Discussion in 'The Hokey Ass Message Board' started by RICH B, Feb 1, 2015.
  1. RICH B
    RICH B
    Looking for ideas for mounting the alternator on the Chev engine going in my '35.
    using a short pump and rams-horn manifolds. I don't want to go to low mount, and I don't like the looks of the Alan Grove style mounts that puts the alt high over the valve cover; but don't know how much room there is to go outward without getting into the hood. Thinking the mid 60's stock location may be too far out; but don't know.
    What are you guys using?
    Thanks.
  2. on my `36 with a 283 i made my own alternator mount , copied the design from one that So-Cal sells. puts the alternator about were the once popular smog pump bracket puts it.....tight to the intake manifold on the p***enger side
  3. Chucky
    Chucky
    I went with a low mount in my A sedan and it barely fits. I used a stock, 3 wire, internal regulator (1973 plus) GM unit. Not sure if you are concerned with how the unit looks but here is something I came across the other day.....
  4. 26 roadster
    26 roadster
    Not in a 36 but you heads have holes. A very tight 62 Jaguar. IMG_196316986094.jpeg
  5. rusty rocket
    rusty rocket
    Look into alan grove.
  6. rfraze
    rfraze
    Bill's Hot Rod Brackets. You will have choices.
  7. RICH B
    RICH B
    So, it sounds like the alternator needs to go on top to fit under the hood.
    How does your R/H mount work out for fuel line and heater hose routing. I looked at the picture you posted on another thread of the yellow motor with the Speedway or smog pump bracket; but it did not have heater hoses.
  8. redo32
    redo32
    Your ***le does mention generators. If your going old style "Jitney Jake" Jim Jacobs markets brackets for generators through Walden Speed Shop. They fit the GM short Powermaster.
  9. RICH B
    RICH B
    I was going to look at the Jitney brackets too; but they don't seem to be on Walden's web sight at this time, emailed Walden; but didn't get a response yet. Saw a picture of an engine with Jake's L/H top mount generator mount really tucked it in nice, instead of sitting so high like Alan Grove's and Bill's brackets end up.
  10. gregga
    gregga
  11. redo32
    redo32
    I bought his L/H bracket but it doesn't clear my 4-2 Weiand manifold. When we were down south for the GNRS we stopped by Waldens and he had a car there with the same manifold. Didn't get a chance to see if the R/H bracket will work.
