Hot Rods 1931 Model A The Harbor Kustom's Coupe, A "Bonneville/Rolling Bones" style build!
Discussion in 'The Hokey Ass Message Board' started by HarborKustomSpeedShop, May 5, 2014.
  1. The37Kid
    The37Kid
    How much shorter will the radiator have to be? Everything looks great. Bob
  2. hotrodderhaag
    hotrodderhaag
    I'm kinda dying inside to see a Sideview of this car all together
  3. The perfect car!! I love it.
  4. yruhot
    yruhot
    Very nice work, like several others I cant stop looking at those motor mounts.I keep saying they are just motor mounts but you make them so interesting to look at. maybe Ive never seen them do like that before. Nice job
  5. Thanks Jim
    Thanks Nick
    Thanks Bob. I moved the grill shell down 2" so hopefully only that much, I might go 3" so there's some wiggle room.
    Heres one from last weekend before I started the hood tops.
    Thank you sir!
    Thanks man, Once you start with the holes your unable to stop...LOL
  6. So Here's an update finally!
    Got the floor and driveshaft tunnel done, Front kickup and transmission tunnel still need fastened down some how. Made new trunk braces and Found a goo pair of houdaille shocks to run up front, of course I had to drill a series of holes in them. the link will be replaced with a dog bone style. Next I started on the hood extension, cut just after the first louver and added needed amount. Hood is stretched 5" over stock. Had a nice weekend a couple back so I got it out in the sun to get a good look at it.
    Here's the pictures.
    Floor
    Shocks
    Hood extension Started with I nice donor one.
    Outside Finally!!
    Justin
    Tim, kidcampbell71, kiwijeff and 3 others like this.
  7. The37Kid
    The37Kid
    Whatever that chop is, it is close to perfect. What is the door window opening height? Bob
  8. alfin32
    alfin32
    from Essex, Ma.
    I agree, I love that chop.
  9. Thanks, its a 5 3/4" chop.
    Thanks you Alfin!
  10. Jersey Joe 67
    Jersey Joe 67
    from J Town
    I just ran across this thread this morning and WOW, I can't say enough how perfect this baby is.
    laidout53 likes this.
  11. Got the hood welded on the sides and hinge tack/started to weld (its further along than this picture)
    But I needed a break from the hood so I mounted the tail lights and made the headlight bar and mounts styled after the Rolling bones one. There low and tucked in tight...
    [​IMG] [​IMG]
  12. A Rodder
    A Rodder
    I haven't been on much lately.....
    You have been busy dude!
    (You and your brother and I talked quite a bit at Puyallup last year in front of my '29)
    Very impressive.
  13. Thanks Joe, yep I remember. You guys going to make it up this year to goodguys?
  14. gnichols
    gnichols
    from Tampa, FL
    That is an interesting s***ch used to extend the hood. Your car is turning out so nice. Gary
  15. A Rodder
    A Rodder
    It us our intent. More than likely bringing the whole family in the wagon this year.
  16. vtwhead
    vtwhead
    Justin, very well thought out build. Great inspiration for the rest of us!
  17. mike bowling
    mike bowling
    Excellent! Who needs a stinkin' 32 anyway!!
  18. Thank you!
    Thanks Mike
  19. hotrodderhaag
    hotrodderhaag
    you have done a hell of a job so far. The rolling bones stance is perfect. and you really have shown a model a can have the same look as the 32s they build. Nice job!
  20. Bam.inc
    Bam.inc
    from KS
    Keep it up & keep posting
    More Pictures!
    That has a bad *** "A"at***ude proportions.
  21. bonesy
    bonesy
    Awesome! All the proportions are perfect.
    laidout53 and Asphalt Demon like this.
  22. Got the steering hooked up, bent the steering arms also. still need to shorten the draggling a little. Switched out the shock links for dog bone ones. Also got both backing plates drilled out. The axle and wishbones will be drilled eventually too.
    kidcampbell71 and kiwijeff like this.
  23. The37Kid
    The37Kid
    It's all looking good, I like the hole layout on the backing plates. Bob
  24. man that thing has style and stance!
  25. JB_roadrage
    JB_roadrage
    Wow... love this car... It's almost exactly what I'd want mine to look like if I ever get around to building one...
