Technical Shock links: Weldable?
Discussion in 'Traditional Hot Rods' started by hotrodA, Feb 6, 2015.
  1. hotrodA
    hotrodA
    I need to cut and modify some two piece, dogbone, Model A/B type shock links, in order to get both cups on the same side. What is the material? Cast steel, I hope. Thought I would ask, before I cut 'em. THANKS!
  2. Unkl Ian
    Unkl Ian
    Check the parting line.
    A narrow parting line is cast, a wide line is a forging.
    I have seen them welded before.
  3. Manager
    Manager
    You can buy them with both cups on the same side.:)
  4. 48-760
    48-760
    from OH
    The early version Model A-early 34 have the holes on opposite sides and the 34-35 have the holes on the same side.
  5. hotrodA
    hotrodA
    Thanks!
    Found the new ones at Speedy Bill's.
    Didn't know about the 34-35's.
    Anybody actually welded any?
  6. Dreddybear
    Dreddybear
    The originals can be modified for sure.
  7. the rolling bones guys do, they shorten them tho.
  8. lowsquire
    lowsquire
    from Austin, TX
    ImageUploadedByH.A.M.B.1423351283.414850.jpg heres some I shortened. They were forged. Tig welded with mild steel rod. No problemo.
  9. hotrodA
    hotrodA
    Thanks, everybody.
    Just what I needed to know.
