Technical Anyone know what year Y Block this is?
Discussion in 'Traditional Hot Rods' started by jermaero, Feb 7, 2015.
  1. jermaero
    jermaero
    from Florida
    Can anyone help me identify what year and possible size this Ford y block motor is? I found it in a barn with the 3 Deuce manifold and transmission still attached.[​IMG] [​IMG] [​IMG] [​IMG]
    kidcampbell71 likes this.
  2. Hard to tell without casting numbers but valve covers and spin-on oil filter would suggest early '60's 292.
  3. 56don
    56don
    Look on the intake port side of the head and see what the casting numbers are.
  4. ALL BLOCKS HAVE 6015 in the block casting number. This is found on all blocks and is Ford's number for an engine block.
    Example- EDB 6015 E
    BLOCK I.D. CODES NOTES
    CEBY 256-272 cu in Cast in Canada. Export block. Used in Canada, Australia, South Africa
    CECK 292 cu in Cast in Canada. Export block. Used in Canada, Australia ect
    EAA 215 cu. in. I-6 1952-53 Ford OHV six cylinder. Increased to 223 in '54. See EBP
    EAD 317 cu. in. V8 1952-54. Early Lincoln OHV engine. Not interchangeable with Ford. see Lincoln page www.ford-y-block.com
    EAL 279 cu. in. V8 1954 Ford HD truck. see Lincoln page.
    EAM 317 cu. in. V8 1954 Ford HD truck. see Lincoln page. www.ford-y-block.com
    EBJ 341 cu. in. V8 1955. Early Lincoln OHV engine. See Lincoln page.
    ECU 368 cu. in. V8 1956-57. Early Lincoln OHV engine. See Lincoln page.
    EBP 223 cu. in. I-6 1954- cars & Lt. trucks. EBR, EBS, EBT in HD trucks
    EBU 239 cu. in. V8 1954 cars only. Cleveland and Dearborn versions.
    EBV 239 cu. in. V8 1955 pickup, small cam bearings www.ford-y-block.com
    EBY 256 cu. in. V8 1954 Mercury
    ECG 272 cu. in V8 1955 to 57 cars and trucks. Typically Dearborn casting.
    ECH 292 cu. in. V8 1955 www.ford-y-block.com
    ECJ 292 cu. in. V8 1955
    ECL 292 cu. in. V8 1955
    ECK 292 cu. in. V8 1955-56 www.ford-y-block.com
    EDB-A 292 cu. in. V8 1955-57 if cast at Dearborn Foundry. EDB found near distributor and generator
    B5AE 272 cu in V8 1959 Replacement block for 272. May have been used for marine & fleet
    PLEASE NOTE: 292 and 312 Blocks were machined from the same castings with the same markings. If the following blocks have EBU main caps it is a 292, if it has ECZ main caps it is a 312.
    ECZ-A 292-312 cu. in. V8 1956 ECZ 6015 A With EBU main caps =292. ECZ main caps =312 Check crank flange or main caps.
    ECZ-B 292-312 cu in V8 1956-57 292 or 312
    ECZ -C 312 cu. in. V8 1957 ECZ 6015 C. 292 with EBU main caps.
    EDB-E 292 cu. in V8 1958-59 cars and trucks to April 59. 312 in Mercury
    B9AE-F 292 cu. in. V8 1959-60 cars and trucks. (312 with ECZ main caps, 1959 & 60 Mercury only)
    C1AE-R 292 cu. in. V8 1961 cars and trucks
    C2AE-C 292 cu. in. V8 1962 cars 62-64 trucks
    B7ME 312 cu. in. V8 1962? later 312 replacement block. C2AE main webs. Only example seen was a marine engine
    NOTE: 6015 is Ford's number for an engine block. All blocks have this number.
    Block identification number generally on side of block above oil filter for blocks cast at Cleveland. Dearborn block I.D. number near distributor and above generator. Most Dearborn blocks used in trucks. No Dearborn blocks after 1957. There were no special truck blocks. Heavy duty trucks with steel cranks used C1AE or C2AE car blocks. Nearly all Dearborn blocks after 1954 were 272's. Most 292 and 312 blocks are from the Cleveland foundry. www.ford-y-block.com
    Deuces, LOU WELLS, BJR and 1 other person like this.
  5. This is a 60s motor; note the unmachined boss for the missing road draft tube behind the fuel pump. This dates it to '62-64, so it's almost surely a 292 and may be a truck motor.
    Deuces and loudbang like this.
  6. jermaero
    jermaero
    from Florida
    Found the casting marks.Its shows it as a B9AE F.
  7. FrozenMerc
    FrozenMerc
    B9 indicates 1959. However, that is the year the mold was made, and not necessarily the year in which the final part was cast and machined. Ford would often use a mold for multiple model years if it was possible. Looks like a 292 according to Rick's List above.
  8. Diggerdug
    Diggerdug
    from Pa
    Now 2019
    old info never die
    My 56' Vicky runs the
    Merc B9AE with triples
    great combo.
    "Some rule with an iron fist, some with an irony" Chick
    Boneyard51 and kidcampbell71 like this.
  9. Moon50F3
    Moon50F3
    How many of us just said to ourselves “Cool. That was almost 4 years ago. Wonder what he did with it after he found the casting marks?”
    Pat
    46international likes this.
  10. Boneyard51
    Boneyard51
    Like those Y blocks and 3 x2s.
    Bones
    egads and 46international like this.
  11. It has a truck bell and trans on it.
  12. A_Burly_Wind
    A_Burly_Wind
    Its a 312. All Y blocks for sale are 312s right?
    guthriesmith, Deuces, 54vicky and 3 others like this.
  13. junkyardjeff
    junkyardjeff
    Just like all 350s came from a Corvette.
    Deuces, A_Burly_Wind and jimmy six like this.
  14. 37KiwiCoupe
    37KiwiCoupe
    Yep, side mounts on the bell-housing and short tail-shaft on the trans indicate it has probably been from a F100 or similar.
    Deuces and Old wolf like this.
  15. Ig Odin
    Ig Odin
    Good morning!
    I'm a new member to this exellent Forum. So to say, a newcomer in for some advise. Here are some pics of a Ford engine that is a barn find. It looks like a Ford Side valve 1172 cc. Well, this topic is devoted to Y-blocks, but I've not found more appropriate thread.
    So, the question is, if it's possible to decode the block cast numbers, in order to identify the production year, manufacturing plant and a car (truck?) that this motor was intended for?
    Unfortunately I do not know the bore/stroke size, for all I have are just pics.
    Thanks in advance for any answer, idea, clue et cetera.
    That appears to be C 155306 number, accompanied with a star:
  16. 51504bat
    51504bat
    And all Hemi's are 392's
  17. squirrel
  18. squirrel
  19. Ig Odin
    Ig Odin
