History Great old Automatic Transmission Names and other trivia
Discussion in 'The Hokey Ass Message Board' started by blowby, Feb 8, 2015.
  1. I also like the names they gave engines too. Packard THUNDERBOLT, etc. Probably could be a different thread but it made me think of that.
  2. blowby
    blowby
    from Nicasio Ca
    Thanks Ray, I had a '58 Impala parts car (ouch, 'parts cars' back then were something like a worn out engine) with a 348 and Turboglide but never ran it. They were not a good trans I take it?
  3. Zerk
    Zerk
    GM's Hydramatic was used, then Li****atic, A Fomoco design that had some problems. Then, in 1955 or so...
  4. 56sedandelivery
    56sedandelivery
    Borg-Warner Drive, Flight-Pitch, Triple Turbine, Flash-o-matic, Multi-Drive, Turbo-Drive, Mile-O-Matic, Powerflite, Ultramatic and Twin Ultramatic, are all other names I found in my 59 edition Motors Manual that have, or may have, been mentioned already. The Turboglide used a FIVE element torque converter, that was primarily responsible for the "shifting" of forward gears; sort of like the "shiftless" transmissions of today. But, I think the name I use for automatic transmissions, "TRANSAMATIC AUTOMISSIONS", exceeds those of all others. I am Butch/56sedandelivery.
  5. woodhawg
    woodhawg
    Not official names, but Slush-O-Matic and ****on-O-Matic for push ****on Chrysler's with push ****on shifting.
  6. My Famous Uncle warned me years ago- automatic transmissions are for shiftless people. :)
    volvobrynk likes this.
  7. BJR
    BJR
    And the clutch fluid used in Hudsons cork wet clutch was called Hudsonite fluid.
  8. blue57ford
    blue57ford
    Some may think of this as lame but I always liked C4 and C6. Simple and to the point.
  9. blowby
    blowby
    from Nicasio Ca
    Boz Scaggs did a whole song about an automatic transmission. He had to modify the name for copyright reasons. Weird.
  10. sunbeam
    sunbeam
    Usally only for a short time.
  11. Hnstray
    Hnstray
    from Quincy, IL
    No, they were not. High failure rate even when driven normally, but even shorter life when abused.
    The 'Gr' (Grade Retard) was like a low gear, and often used as such, and hastened the trans' demise.
    I had a friend in those days with a '58 Impala, 348 Turboglide, a 'spirited driver', and he soon proceeded
    to demonstrate it's short life potential. :D
    Ray
  12. Early Holdens in Australia had a Hydra-matic, it was fun to drive because you had to wait for the gears to catch up with you (you kept your fingers crossed praying it would go into gear)
  13. Someone beat me to the slim jim, how about the switch pitch 400 in late nailheaded buicks (SP400). The Ford-o-matic too.
  14. ClayMart
    ClayMart
    "Chinese Six with a Typewriter" ;) (slant 6 with a push-****on Torqueflite)
    volvobrynk and Hnstray like this.
  15. Hnstray
    Hnstray
    from Quincy, IL
    "Typewriter Torqueflight" is what my brother used to call 'em.......
    Ray
  16. Dan in Pasadena
    Dan in Pasadena
    Someone mentioned Fluid Drive?
    Check out the bumper on this beauty:
  17. blowby
    blowby
    from Nicasio Ca
    What is the green dot for?
  18. Hnstray
    Hnstray
    from Quincy, IL
    Green dot and small white dot, to it's left in photo, were both 'Drive' positions. One of which only used 2nd and 3rd gear....the other engaged 1st, 2nd & 3rd. To the best of my recollection, the green dot was for all three gears.
    Ray
  19. WQ59B
    WQ59B
    'Slim Jim' was the nickname for the Roto-HydraMatic.
    Alongside the RHM @ Pontiac was the Super HydraMatic
  20. s55mercury66
    s55mercury66
    from SW Wyoming
    On the Cruise-o-Matic, we used to say white dot for snow (or slow), green dot for go. First year c6's came with a valve body set up the same way, and I think c4's thru '66 did also.
  21. plymouth1952
    plymouth1952
    Slim Jim
  22. volvobrynk
    volvobrynk
    from Denmark
    Never said it was good, but I love music, and some memories just trigers an emotion and Leeds to a song, or maybe to sing. Thank god im alone when I feel like singing :eek::oops:
  23. Lincoln called it "Li****atic" in 1942.
    Cosmo
    296ardun likes this.
  24. sunbeam
    sunbeam
    Some I didn't see Gyromatic, fluid torque, fluid matic. super matic and flash away. Then we have the hill holder transmission.
  25. Hill Holder was NOT a transmission, it was an optional feature on Studebaker's with a manual transmission (also new Subarus, also with manual transmission, tho no longer optional, is standard).
    Cosmo
  26. Super turbine 300 and 400
  27. I hear you on the music and memories connection.
    I lost my virginity while Kashmir by led zeppelin was on the radio.
    It's automatic
    It's systematic
    It's hydromatic
    Why it's a grease lightning (Grease lightning)
    overhead lifters
    four barrel quads
    Fuel injection cutoffs
    chrome plated rods
    With the four speed on the floor ( to go beside the hydramatic And automatic I guess)
    we'll be getting lots of ***
    coasting through the heat trial
    chicks'll cream
    some purple hued tailpipes
    some thirty inch fins
    duel muffler twins
    With new pistons, plugs and shocks I can get off my rocks ( sock ****ers car club maybe)
    she's a real ***** wagon
    Go grease lightning you're burning up the quarter mile
    (Grease lightning go grease lightning)
    Go grease lighting you're coasting through the heat lap trial
  28. Rusty O'Toole
    Rusty O'Toole
    You forgot the Ultimate, Packard's Ultramatic
    Diarrhea = a fart with Fluid Drive
    4 on the floor, 3 on the tree or 2 in the glue.
  29. blowby
    blowby
    from Nicasio Ca
    Whoa, a late entry! I remember those, buddy had one in a Cutl***.
    Packard 'Touch ****on Ultramatic'
  30. FrozenMerc
    FrozenMerc
    Not to forget the 1941 Chrysler M4 Vacamatic semi-automatic transmissions and its later post war cousin the M6 Presto-Matic
    Ford Anglia's were equipped with "Newton Drive". Essentially a clutchless manual trans.
    Even the import guys got into the odd names like Porsches Tip-tronic manul-matic transmission and Volvo's related Geartronic boxes and Audi's multi-tronic CVT unit.
