My first build lots of questions 49 styleline deluxe
Discussion in 'The Hokey Ass Message Board' started by ratfink707, Jan 6, 2015.
  1. ratfink707
    ratfink707
    First build so far got a centerbolt 305 and t350 I'm at the rear end now I got it from a 87 4x4 s10 blazzer do I make and weld on new pads or is there easy way I keep seeing drill hole I 1/2" forward ?
  2. txturbo
    txturbo
    buy new pads and weld them on......you don't have to move the rearend by redrilling the holes unless you want the wheels to be centered in the fenders.
  3. deto
    deto
    If it were mine, I wouldn't cut off the pads if they are the correct width. Just re drill them.
    If you cut the pads off, and weld new ones on, then the rear axle should really be taken to a rear end shop, and straightened.
    This is a step that a lot of builders overlook, but I feel it's critical if any serious welding is done on the axle.
    I think centering the axle is crucial. even though its only 1.5", you will notice it immediately if you don't do it.
    If you have any questions on building your 49 feel free to message me.
  4. ratfink707
    ratfink707
    Thanks guys yes I want it centered I'm on way home now with rear end
  5. bobss396
    bobss396
    Just thinking out loud.. how about an offset lowering block to get the rear centered? At the worst you may need some machining done to some of the other parts.
  6. ratfink707
    ratfink707
    More progress
  7. ratfink707
    ratfink707
  8. ratfink707
    ratfink707
    Anyone have suggestions on where to get windshield and back gl*** seal ?
  9. Binger
    Binger
    from wyoming
  10. HOTRODPRIMER
    HOTRODPRIMER
    The car looks like it has a solid body! HRP
  11. butcherted
    butcherted
    from hagerstown
  12. seanbelushi
    seanbelushi
    You can try chevsofthe40s or National Chevy ***ociation for all the new stuff you need. I've got a bunch of leftovers and spares, so contact me if you need any shiny bits.
    Sean
  13. ratfink707
    ratfink707
  14. ratfink707
    ratfink707
    More
  15. 49ratfink
    49ratfink
    ooh, you have the rare 1949 Chevrolet accessory steering wheel. that's worth something even all screwed up. Nice ones go for $500 - $800.
