Features Let's see Model A's lowered without dropped axles
Discussion in 'Traditional Hot Rods' started by Hot Rod 50, Feb 8, 2015.
  1. Hot Rod 50
    Hot Rod 50
    This is a killer car I love it
    And I will do this. I'm going for basically a high school war era build. Some kid that built this in the early 40's. I like the t spring and reversed eye from spring. That may be the way to go.
    Thanks again guys
    volvobrynk likes this.
  2. Pat Pryor
    Pat Pryor
    Yes I'll find the link for you
  3. trucker1
    trucker1
    Check Speedway catalog for a reversed eye spring that's made flatter to start with that's the right length from Posies, then round and taper the ends. Good price, service, and product.
  4. volvobrynk
    volvobrynk
    from Denmark
    Thank you, liked it then, like it now. But lost track at some point.
    Looking forward to link!! [emoji5]️
  5. CTAV8
    CTAV8
    Dropped axle and mechanical brakes. It's really not that difficult to do. You can make perch extensions as we did or use '32 perches and axle ($$$$). Also another book that's very useful is Mike Bishop-Vern Tardell "How To Build A Traditional Ford Hot Rod."
      1.4 MB
      1.3 MB
      394.5 KB
      515.2 KB
    marioD, cederholm and Entlebucher like this.
  6. Hot Rod 50
    Hot Rod 50
    Man this threads taking off. Thanks for all the info and great cars guys. Keep em coming.
  7. Hot Rod 50
    Hot Rod 50
    This is exactly what I was looking for. Awesome car. What drums are those?
  8. CTAV8
    CTAV8
    They are '35 mechanicals, 12" diameter with 1.75" shoes, just like later juice brakes.
  9. 62pan
    62pan
    "Most cars prior to WWII (1941 for us here in the States) used the 32-6 axle, 32-4 perches, reverse eye springs, and mechanical brakes. Dropped axles and juice brakes started showing up (together) just prior to the war. Honestly don't think I've ever seen a period photo of a "dropped axle" AND mechanical brakes..."
    If you check out the Don Ferrara collection on the AHRF site there is a photo of his roadster with a dropped axle and mechanical brakes. Photo number 96. I dont know how to copy the photo and add it here.
  10. vwdave30
    vwdave30
    Speedway crossmember and spring
  11. CTAV8
    CTAV8
    [QUOTE="62pan, post: 10839932,
    If you check out the Don Ferrara collection on the AHRF site there is a photo of his roadster with a dropped axle and mechanical brakes. Photo number 96. I dont know how to copy the photo and add it here.[/QUOTE]
    Good sleuthing, 62pan. I can't see the axle too good on my iPhone but the perches look like '32-'34. That's a very nice way to do it but you have to drop the axle exactly the right amount. We matched perch extensions to an already dropped axle...... much easier to marry together.
  12. 62pan
    62pan
    Complete 32 front end with a reversed eye A spring. Rear spring is A with 7 leaves.
  13. gwhite
    gwhite
    SUPER MODERATOR
    I believe this is the pic you're referring to;
    If memory serves, that picture was taken between 1945 and 1946, after Don upgraded to a V8. I've seen a couple others from the same time period (1945-48) with mechanicals and dropped axles; I meant to say that I don't recall ever seeing a picture of a car with a dropped axle & mechanicals before the war.
    volvobrynk and jmiller1918 like this.
  14. gwhite
    gwhite
    SUPER MODERATOR
    Here's another; Bob Wenz - 1946
  15. swingkingvintage
    swingkingvintage
    Rear shot of car, heated spring until it touched the rear! If I were to do again I would take a few leaves out of spring. It took me some time to figure out how to post some more photos on here, I'm a car guy not so much a computer guy! oldtime3.JPG
  16. 62pan
    62pan
    Thanks Gary that is the photo I was talking about. I did a lot of research before starting my own prewar project so I knew drop axles and mechanical brakes were used together. I do believe you are correct in saying most are used around 1946 and not before WWII. Its hard to find a car with mechanical brakes after 1946.
    volvobrynk and gwhite like this.
  17. earlymopar
    earlymopar
    What a gorgeous roadster Pat!
  18. GZ
    GZ
    from Detroit
    Here's my 1928 Roadster which has a 8 leaf Model T rear spring and a reversed eye front spring.
    Also a picture of my former 1929 tudor that has the same combo but shows the results on a car with fenders. Both use 16 x 7.50 and 16 by 6.00 tires.
    Dannerr, Outback, volvobrynk and 2 others like this.
  19. gwhite
    gwhite
    SUPER MODERATOR
    :) You know we're "brothers from other mothers" (or whatever the kids say), right? I did the same thing, and aside from the hand-me-down jalopy, I agree 100%. It's amazing how slow some technology (the V8) was to be adopted, while others ("aircraft shocks" & juice brakes) came on pretty quickly.
    I think the strangest combo I've ever seen is this 1947 photo from Don Montgomery's Old Hot Rods S****book - dropped axle, mechanicals, and "aircraft" shocks. Bizarre!
    Hitchhiker, BigO, Stogy and 3 others like this.
  20. Pat Pryor
    Pat Pryor
  21. Pat Pryor
    Pat Pryor
    Tha
    Thanks!!
  22. woodz
    woodz
    Posies reversed eye springs front and rear with 1 or 2 springs removed from each (cant remember) and it ended up lowering it 3".
    I have a 36 axel that will be going into it as well, not sure yet how I am going to get the rear down another 2" to match the front axel.
    Outback and CTAV8 like this.
  23. Jersey Joe 67
    Jersey Joe 67
    from J Town
  24. orangeamcs
    orangeamcs
    So if I was to have a model a axle dropped so that I could use 32-34 perches without extensions and have everything line up what amount of drop would I be shooting for.
    Outback likes this.
  25. kiwikid
    kiwikid
    just starting a project like this myself , in regards to removing leaves from the rear spring how man did you remove, which ones , ( the top ones ?) and how much did it lower the rear ...any problems thanks in advance
  26. waxhead
    waxhead
    from West Oz
    Model A, drop axle with mechanical brakes
    Outback, tony starr and CTAV8 like this.
  27. tony starr
    tony starr
    Cold Canuck, 63savoy, BigO and 7 others like this.
  28. ratreo
    ratreo
  29. ratreo
    ratreo
    I believe that the vented brake drums are referred to as "Mountain Brakes". They had the openings so as to help cool the drums when you were dealing with a lot of elevation changes. I have a set that I use to mock up my frames so they'll roll around prior to adding backing plates and brakes.
  30. banjorear
    banjorear
    '32 axle with reversed eye spring. A leaf or two was removed. A lot of the work was done by our own Zach Suhr!
    Outback, jmiller1918 and Entlebucher like this.
