Technical 31 ford Tudor
Discussion in 'Traditional Hot Rods' started by David Knapp, Feb 9, 2015.
  1. David Knapp
    David Knapp
    Now for the next step on my build the brake peddle and booster,looking for a good system if any one has any suggestions ,I am running a 302 power plant ,mild cam .Thanks for any advice.
  2. Schwanke Engines
    Schwanke Engines
    I am using hanging clutch and brake pedals from a race car in my 28 Tudor.
  3. unkledaddy
    unkledaddy
    You don't really need power brakes on that car.
  4. bgaro
    bgaro
    ansen style pedals and a 62 chevy truck clutch/brake master woulda been a hot setup. agreed, you don't need a booster. that thing is so light. it'll stop on a dime without power and drums all around.
  5. Well, I'll catch hell for this but I used a '39 style master cyl. (single circuit) and made a bracket to mount it under the floor no booster. Used the stock Model A pedal and the early ford brakes. that set up works fine after you get the shoes adjusted correctly.
  6. bartmcneill
    bartmcneill
    from Ada, OK
    Hey 46international, you got pictures of the brake pedal ***embly?
  7. David Knapp
    David Knapp
    Barmcneill has a geat idea ,lets see some or those pictures of these great brake setups .
  8. hotrod harry
    hotrod harry
    from wisconsin
    made my own reverse hanging pedals ,obviously if you use original tank this setup pedalssmall.jpg ain't working
    grego31 likes this.
  9. David Knapp
    David Knapp
    Awesome set up hotrod Harry ,thanks for sharing .
  10. David Knapp
    David Knapp
    Moving along on dream project here's some picture of the 302 bored 30 over ,mild cam . image.jpg image.jpg image.jpg
  11. David Knapp
    David Knapp
    Next finding the right hugger headers that will work .
  12. 28TudorAZ
    28TudorAZ
    Any updates? I am sure there are plenty. Very similar build to mine.
