Projects 1929 cabriolet or coupester
Discussion in 'Traditional Hot Rods' started by DMcNulty1, Feb 16, 2015.
  1. DMcNulty1
    DMcNulty1
    I bought this project a few months back and I picked up a ford 8ba flathead for it and a coupe roof now that I start to get into the project someone was trying there best to make a coupester out of it I found that the quarters where shorten about 3-4 inches i would really like to do a coupe but it seems like it will be much more work any ideas what should I do and the spilt windshield is up for sale I don't need it I have no idea what it's from
    volvobrynk likes this.
  2. timwhit
    timwhit
    I think you have enough to actually build a decent car. It will take some work but they all do. It would be really cool with the poles laid back and a chopped convert top!! I'd go for it if I were you. Here's a pic of what I started with. Tim 102_0591.JPG
  3. DMcNulty1
    DMcNulty1
    I was thinking about that too if I would use the same system that a Corvette has with hard top Removable
  4. DMcNulty1
    DMcNulty1
    But I do live in sunny California and a lot of roadster are out here not to much coupes most of everything I see has a small block 350 not to many flatheads running around in my area just a lot of rat rods
  5. missysdad1
    missysdad1
    You've got what you need to build a first-cl*** coupester on either the A frame that's under it now or a '32 frame that would probably result in a prettier car. Lots of people poo-poo the idea of a coupester ever being pretty, but in response I submit the following evidence...
    Edit: Wait, wait...this ^ ^ ^ is NOT my car, but it is one that was made from a coupe and is one that I admire greatly. Perhaps someday MY coupester will look as good.
    Right now I have my car torn down and am sorting out the "rough mechanical edges" left by the previous owners/builders while at the same time turning it into a highboy on the original A frame. When it is presentable again I'll post photos. Sorry for the confusion.
    Truthfully, as I am discovering, coupesters do not have the same kind of charm as do real roadsters when they are stripped to the bare essentials. The primary area for concern is NOT the longer doors, but rather the door tops and the windshield area.
    As the above example makes perfectly plain, slimming the door tops and grafting a roadster windshield onto a coupe body is pretty much all it takes to make a really smooth and sleek hot rod out of an otherwise ugly duckling...
    waxhead and volvobrynk like this.
  6. timwhit
    timwhit
    Ain't nothin wrong with that!!
  7. DMcNulty1
    DMcNulty1
  8. thirtytwo
    thirtytwo
    Where is that car located now missysdad? The frame under this one was a hybred of sorts... 32 truck frame , sectioned 3" at firewall , same can be don with tubing.. Full floor, with channed look image.jpg
  9. missysdad1
    missysdad1
    I have no idea. I got the photo from another thread here on the HAMB and saved it because it is such a nicely proportioned coupester. I'm sure the owner won't mind my using his car as an "ideal" towards which I effort with my own coupester...I hope not anyways.
  10. thirtytwo
    thirtytwo
    I have some pics of when I built it if you want to see how some stuff was done
  11. bobo1
    bobo1
    from France
    If you have some pics I'm very interresting to have some information of this build
    I'm making the same on my modified , And I have about concerns(marigolds) with the junction of bottom
  12. thirtytwo
    thirtytwo
    I did very similar to yours made a flat pice out of 1/4 with a stud for the post then made the sheet metal blend to it image.jpg image.jpg image.jpg image.jpg
  13. bobo1
    bobo1
    from France
    Thank you for your answer
  14. missysdad1
    missysdad1
    I'd very much like to see as much construction background on this car as you have, but I don't want to risk hijacking the original poster's thread. Would you be interested in starting a thread on just that car alone? I'd sure subscribe!
  15. Squablow
    Squablow
    For the OP's car, if they were trying to make a coupester out of it, why would they shorten the quarters? Aren't the quarters longer on a roadster, and the doors longer on a coupe? that's a really odd mod. I don't think it'd be that tough to add the length back in to put the coupe roof on.
    If you want a coupe, I'd add the length back in and make a coupe. If you want a roadster, keep going where the last guy left off. Either way will be quite a bit of work but should be do-able.
  16. thirtytwo
    thirtytwo
    The1/4s look like the correct length to me the door opening looks right also , the cabin area is really long on a sport coupe , I have seen the doors shortened and 1/4s shortened to make the ****pit more roadster like , but it also shortens the wheel base , I just made my upper decklid pannel longer cause I had to make one anyway..
  17. thirtytwo
    thirtytwo
    I meant to do a build thread the goal was a painted hotrod for 5k doing everything the hamb experts tell you not to do.. But I built it in a winter unemployed , for some reason I lost a lot of pics I have a couple of door windshield pics , but the car was kinda a throw together
