Customs Lowering
Discussion in 'The Hokey Ass Message Board' started by dada, Feb 18, 2015.
  1. dada
    dada
    If I want to lower the front end of my 1948 coupe about two inches how safe is it to remove leaves from the spring setup and how many and which ones. Thanks
  2. Jalopy Joker
    Jalopy Joker
    '48 what? Post pics of ride & suspension
  3. wbrw32
    wbrw32
    I guess all newbies think everyone here are mind readers...Maybe its a 48 Henway..LOL
  4. "what's a Henway?"
  5. 55Caddy62
    55Caddy62
    A good one weighs about 2 to 3 pounds. ;)
    lawman likes this.
  6. X38
    X38
    Being a traditional hot rod place, I'm going to ***ume it's a FORD!
    But, I have been caught with this so many times on this place with similar thread ***les it's just as likely to be an International pickup.:rolleyes:
  7. HOTRODPRIMER
    HOTRODPRIMER
    Unlike many guys that post on this site... this gentleman did fill in his profile and it appears he has a 1948 Ford Coupe.
    I think I would remove one or two short springs at the top of the pack and maybe a reversed spring would help. HRP
  8. 302GMC
    302GMC
    from Idaho
    Since you're new, start with the best - drop the axle. You learn to cobble stuff AFTER you learn how to do it right.
  9. dana barlow
    dana barlow
    from Miami Fla.
    If you take out leaves,it gets weaker too and lowers it,but now that is a weaker spring=it will bottom out much EZer,not just cuz u have less room.but cuz it takes less bump to move more from drop in spring rate. So rearking spring is a better way,or use a droped axle
  10. Jalopy Joker
    Jalopy Joker
    so, guess that it is a Ford. do not remove the top short leaf. do not remove two that are touching each other - remove only two. will lower about an inch. want to lower more can de-arch springs too. that is about it unless you run shorter than original size tires, like maybe a 205/60/15. 235/60/15 for rear.. for handling need front panhard bar & stabilizer bar. for front shocks use rear shocks from a early 60's Corvette - Tokico gas shocks work good. always can go with mild dropped axle, like a 3" instead which in reality will give you closer to two inches. . can not go real low if you want to be able to turn wheels. might as well add disc brakes while everything is apart. upgrading to a better steering box would not hurt.
