Technical trans shifter pins
Discussion in 'Traditional Hot Rods' started by 4ford, Feb 21, 2015.
  1. 4ford
    4ford
    from Eagan. Mn
    need to replace the seals on my shifter lever on trans how do I remove the pins on the arms??? [​IMG]
  2. EnglishJon
    EnglishJon
    A semi educated guess says they are tapered pins, and should be knocked out from underneath. If this is the case, use a straight punch. New pins might be a good idea on the reinstallation
  3. 4ford
    4ford
    from Eagan. Mn
    I was thinking on introduce some heat
  4. fatkoop
    fatkoop
    Look closely to see if one end of the pin seems to be larger than the other. If so, its a tapered pin. Use a punch on the small end to drive the pin out. I re-drill the holes to accept a roll pin, 'cuz I expect to dis***emble it again sometime in the future, and a roll pin is just easier to deal with. I don't think heat on the side case or shift forks is a good idea at all.
  5. joel
    joel
    From your pic, drive out the pins from the bottom; however, you may have to do a little careful grinding on the end of the pin, because it was peened over to keep it in place. fatkoops idea with the roll pins is a good one. I bought replacements for mine and the holes already had too much wear; the new pins were loose.
