Customs Do you cadillac caps take special wheels
Discussion in 'The Hokey Ass Message Board' started by Fastlane1, Feb 19, 2015.
  1. Fastlane1
    Fastlane1
    I picked up a set of cadillac caps and I was wondering if they take a special steel wheel for them to fit? Thank you.
  2. chaddilac
    chaddilac
    They take a dished wheel.... no raised center in it. Buick had a similar wheel or they might be the same.
    lothiandon1940 likes this.
  3. Mr48chev
    I'm pretty sure that those are 56 caps and they do only fit on certain Cadillac rims as far as I know.
  4. wvenfield
    wvenfield
    Cadillac rim on the front of this Pontiac. You can see how much deeper it is than the Pontiac rim on the back.
  5. The caddy rim has a deep "first step" , you can see it in wvenfields picture. They even have special wheel weights with a longer mounting arm to fit these types of rims.
  6. falconsprint63
    falconsprint63
    from Mayberry
    depends on the cap. some yes, some no. generally, in my experience if it's a rim clip probably not, center clip probably. disclaimer I generally only mess with 50-53 sombreros.
  7. dan c
    dan c
    had a '79 coupe deville and the wheel covers attached with three little clips . those wheels had a lip on the rim, but it threw 'covers with great regularity.
  8. 1929sedanrod
    1929sedanrod
    I have caddy caps on crown Vic wheels no problem but they didn't fit on 70c10 wheels
  9. O.Hove
    O.Hove
    from S.D.
    Look like 58 caps to me. Only fit Cad rims, others with modifing
  10. ratrodcentral
    ratrodcentral
    Like the others said 1956 and will only fit the deep rims. I have cut the centers out of these 56's. The outer part makes a hell of a nice trim ring.
