1952-59 Ford Motor mount quality
Discussion in 'Off Topic Hot Rods & Customs' started by JeffB2, Jun 25, 2014.
  1. JeffB2
    JeffB2
    from Phoenix,AZ
    This has come up before regarding SBF swaps,as you know most motor mounts are no longer USA made and the Chinese and India rubber quality is piss poor.The ANCHOR mounts many of us used and are listed in the "Sticky FAQ" have been failing.I ran across a post on hotrodders.com that also showed separating mounts,I ran across a deal on headers I might jump on as I have a cracked manifold that needs replacing,so looking at my '54 I used to be able to get my pinky between the manifold and steering box,not now the mount has settled and is right on it and to make things worse the mount stud is now turning in the rubber and will have to be cut off.:mad::mad: Best to buy these,I guess: http://www.jegs.com/i/Prothane/311/6-501-BL/10002/-1?parentProductId=762288# Then I found this :D http://www.ebay.com/itm/1985-1995-M...r_Truck_Parts_Accessories&hash=item1e8d5e5562 WOW! beats Jeg's and Summit by $30
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    I got really lucky today,a guy swapped out a built 5.0 in his Mustang for a Coyote crate motor and I scored the Prothane mounts like above for $50 off craigslist.They are super beefy like night and day from those junk Anchor mounts,I guess it turned out OK that I had to put things on hold because of some recent medical issues.
  3. Texas57
    Texas57
    I'll be keeping an eye on the Anchors I've got in mine, and I'll p*** the warning on to 3 or 4 guys I know that are just starting the 4.6 dohc swap into '57's and have had the anchor pn's referenced.
    Thanks Jeff
  4. old lady's mad
    old lady's mad
    yeaup anchors are junk. i can say that from being a professional tech. unfortunately for alot of stuff on the rd thats all you can get.
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    Here is the Prothane mounts 6-501 6-301 Prothane 001 (Large).jpg [/ATTACH] peller-poster-445x630.jpg
  6. JeffB2
    JeffB2
    from Phoenix,AZ
    I guess we answered that question! ;) All USA made quality too.
  7. JeffB2
    JeffB2
    from Phoenix,AZ
  8. HOTRODPRIMER
    HOTRODPRIMER
    I just replaced the second set of motor mounts and this time I heeded Jeffs advice and used the Prothane mounts,hopefully the last set. HRP
  9. Copper Top
    Copper Top
    Thanks Jeff B2 for the heads up on the Prothane mounts, I am going to need mounts later as mine don't look that great. Hope your medical issue is solved.
  10. Zapato
    Zapato
    Anyone try the Westar brand motor mounts [made in India] ? If so please give an honest review. thumbs up or down ?
  11. JeffB2
    JeffB2
    from Phoenix,AZ
  12. HOTRODPRIMER
    HOTRODPRIMER
    Having replaced the second set of Anchor motor mounts in 3 years,I will NEVER use another ****py set of mounts made in India! HRP
  13. Zapato
    Zapato
    Steele Rubber Products still makes motor mounts right here in the USA, checked earlier today and they make them for y-blocks going in 55-59 fords, didn't check for others but am sure they'll be much better than any offshore junk. And unless you're really hammering your ride the Prothane mounts are a bit of overkill.
    Texas57 likes this.
  14. JeffB2
    JeffB2
    from Phoenix,AZ
    I hope you call them and confirm it,sadly Steele is doing some outsourcing too as some members found out. During the Korean War and World War II America became an industrialized nation and produced everything we needed here at home. Akron,Ohio was once the tire capital of the world and Pittsburgh,Pa the heart of the steel industry, not any more.Over 85% of our s**** metals are exported to be used in China and India,I guess we have over zealous liberals and the EPA to thank for that. :(
  15. Zapato
    Zapato
    Contacted ''Steele'' today about country of origin on their stock 55-59 V8 mounts will update this once they respond.
  16. JeffB2
    JeffB2
    from Phoenix,AZ
  17. HOTRODPRIMER
    HOTRODPRIMER
    Jeff,did you ever get around to changing your mounts? HRP
  18. JeffB2
    JeffB2
    from Phoenix,AZ
    Looks like next week if nothing comes up, I'm getting some help to organize the garage first it is a disaster.
