Projects Help to ID a Model A back half
Discussion in 'Traditional Hot Rods' started by johnc451, Dec 21, 2013.
  1. johnc451
    johnc451
    I picked up this Model A back half years ago and it has been in a corner-etc. Looking at it today I am thinking it is a cabriolet section rather than a roadster. Lock area looks high for a roadster and the contours do not match my roadster doors. I can make it work for me but am thinking a restorer might have a harder time finding this than a roadster section. Input appreciated. John 845-266-5304
  2. Maybe a 30-31 Sport Coupe???
    Dustin
  3. b-bob
    b-bob
    My guess is 28/9 sport coupe, I am looking at the wide band on the door.
    I just bought one of these a couple of weeks ago. All most all stock.
  4. cmyhtrod
    cmyhtrod
    from ct
    Definitely not a roadster
  5. johnc451
    johnc451
    Is there a way to tell if this is 28/29 or 30/31 since there is no cowl? Thanks guys
  6. Hot Rods Ta Hell
    Hot Rods Ta Hell
    From a quick glance at 50 feet, 28/9 has no wheelwell bead where 30/1 does. Beading at p***enger compartment wraparound is different. General shape of quarter panel is different.
    Without google image searching and posting for you, I'd recommend looking at Brookville's catalog photos to familiarize yourself.
  7. Rich Wright
    Rich Wright
    Subtle but major differences between '28/'29 and '30/'31.
    Post some better pictures and should be pretty easy to pinpoint what you have.
    It's definitely a Sport Coupe, though...based on your pics
  8. eicke
    eicke
    Wheel wells pinpoint it to a 29/29 coupe. What type of coupe? :confused::confused:
    28/29 have no beading where the fender attaches and the upside down "Y" 's inside the wheel well are designated for a coupe, unless changed.
  9. johnc451
    johnc451
    From the input I've gotten and the photos you all have sent---28-29 sport coupe----THANK-YOU all for the good info---John
  10. millersgarage
    millersgarage
    it's a Special Coupe.
    28-29
  11. millersgarage
    millersgarage
    see how the quarter window area is a separate piece?
  12. Bader 2
    Bader 2
    Sport coupe and special coupe quarters are one in the same!
  13. Larry Pearsall
    Larry Pearsall
    Larry in Brookville, You ask if I still hav tag for sale.. They are listed on Ford Barn..
  14. Mo rust
    Mo rust
    Sport coupes don't have metal tops. This is a regular steel top coupe. The top is made in a separate piece on the 28/29 coupe and come apart. If you can't find the piece to replace the rear window, I would cut up a rear window panel from a sedan. Those are easy to find.
  15. Reds 29
    Reds 29
    That's a special coupe from 28-29. Note the slotted area around the quarter windows, cloth was attached to it. Also the missing area around the back window. It is like that because the special coupes were wood around the back window, with cloth covering. Standard coupes had metal around the back window. I will add to what Bader said Special coupe, and sport coupe quarters are one in the same. So are standard coupe quarters.
  16. carmuts
    carmuts
    Special Coupe without a doubt. Rod
