I am selling my 1930 Model A ford coupe hotrod. It is drivable and could be driven as is as a rat rod or slicked up as a street rod. It is a rumble seat car and all patch panels have been installed. No rust areas left to fix. All gl*** is out of the car but I have the original gl***. some are good and some should be replaced. I have new window channels for it. Engine is a Chevy 454 with a very stiff Lunati cam. It has a tunnelram with two 650 Holleys. The engine runs perfectly and is a handful in this light car. Has an aluminum radiator with electric water pump. Transmission is a Turbo 350 with a 3000 stall converter. Rear end is a narrowed Ford 9 inch with 373 gears. Coil over shocks on rear. I bought this car as a running original. I have many pictures of the build. Original frame has been boxed and cross braced. The car has not been wired for lights. It has a new 4 inch drop front axle. Kingpins, front disk brakes, and all steering parts are new, mostly from Speedway motors. Headlights have built in turn signals. Please feel free to ask any questions you have. The coupe is drivable and ready to go once a little wiring is completed. The transmission is presently in the transmission shop being rebuilt. It will be reinstalled before sale. I will drive 200 miles to help with delivery. 14,000.00 OBO Walnut, Ms. 662 415-7698 Lots of pics available. See More
I have several rolls of the aluminum foil insulation for the top and sides and a roll of black floor insulation/carpet padding.
