Technical 53-56 f100 axle ratio ID
Discussion in 'The Hokey Ass Message Board' started by sqweaka, Feb 25, 2015.
  1. sqweaka
    sqweaka
    can anyone please tell me what the stock axle ratio should be on an 53-56 f100 axle or if there are tags on the axle it ID what the ratio is
    many thanks in advance
  2. 53 effie
    53 effie
    From my experience, it was on the ID plate on the glove box door. My F-100 said 3.92 for the Dana 44 behind the straight six.
    sqweaka likes this.
  3. V8 Bob
    V8 Bob
    I'm not sure about '53-'55, but '56 F-100 ratios were 3:92, 4:09 and 4:27 to 1. There should be a tag on one of the rear end cover bolts.
    sqweaka likes this.
  4. Rocky
    Rocky
    Classified Editor
    My 49 F-1 was 4.27
  5. Gene Boul
    Gene Boul
    Glovebox plate. Decipher the code. g
  6. sqweaka
    sqweaka
    Thanks everyone I'll let you know what we find
  7. sqweaka
    sqweaka
    been told there are no tags on the diff and the glove box is missing/removed from the truck! (the axle has actually been removed from the truck and the truck has been sold on, i think) ive seen a picture of the axle and it looks to be a dana 44 unit.. if i remove the cover will there be markings on the crown wheel to id the ratio if i go to view it? or can you turn the drum and count the drive flange to work out the ratio roughly (does that even work?)
  8. jseery
    jseery
    from Wichita KS
    Easy to check, just mark the wheels (or drums or axles) with chalk and turn the pinion or the wheels and do some counting. The axles have to both turn together because of the differential, that is the only issue. Count the number of pinion turns for one complete turn of the axle/wheels. You will end up with some fraction like 3 1/4 or 3 3/4 or 4 1/8. You can guess the closest known ration from there if you are carful when you count the turns.
    sqweaka likes this.
  9. Should be numbers on DS end of pinion,,divide.
  10. sqweaka
    sqweaka
    no tags on the axle had to pull the diff cover off in the end to count the teeth.. 47 on the crown wheel, 12 on the pinion = 3.916 which is what i was hoping it was.. result! thanks all
