Technical 15 Inch Hubcaps on 16 inch wheels
Discussion in 'The Hokey Ass Message Board' started by BrokenJoints, Feb 28, 2015.
  1. BrokenJoints
    BrokenJoints
    I want to put new hubcaps on my ride but they only make the hubcaps in 15 inches. Can you fit 15 inch hubcaps on 16 inch wheels? The hubcaps are Chrysler and the wheels are Coker Universal Hot Rod Wheels.
  2. BrokenJoints
    BrokenJoints
    Is it even possible to fit original Chrysler hubcaps on Universal Hot Rod Wheels?
  3. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    With a welder ;)
    Thaplumbr likes this.
  4. X38
    X38
    Hubcaps or wheel covers? They are different. Wheel covers usually clip in around the rim, so if the wheel diameter is larger than the size the cover is made for, no, they won't clip on.
  5. BrokenJoints
    BrokenJoints
    I was deciding between these two. They are sold on Hubcaps.com. I think they are cl***ified as wheel covers I'm not sure image.jpg image.jpg
  6. wraymen
    wraymen
    Seen it once with a 14 attached to a 15 trim ring but then you got 2 valve holes. Don't know how it was attached couldn't see anything but it looked weird. Paint the wheel and find some dogs or center caps.
  7. scrap metal 48
    scrap metal 48
    You may be able to adapt the 15" wheel cover to a 16" beauty ring.. I spot welded one that way for a spare tire in one of my coupes.. I hope someone comes up with a better way to do it because 16" wheel covers are very hard to find...
  8. Mark T
    Mark T
    I'm pretty sure Chevrolet did this a few years ago on the 16'' Suburban wheels, they used a 16'' trim ring and snapped a 15'' hubcap into it.
  9. clem
    clem
    Where there is a will - there is a way....
  10. manyolcars
    manyolcars
    When I got my 39 Ford someone had used trim rings and used three very small screws to attach the hubcaps, just like they used to do with Moon Discs
  11. 59Apachegail
    59Apachegail
    from New York
    There was a tech/thread on this about two years ago. I think the author used cadillac caps
  12. 19Fordy
    19Fordy
    I hope someone can find that thread.
  13. Mark T
    Mark T
  14. 19Fordy
    19Fordy
    Thanks for finding and posting those threads.
  15. Artistictouch
    Artistictouch
    I'm quite late here but Ford made 16 inch Reducer Trim Rings to Fit 15 inch Hubcaps
    These rings were made by Ford so you could put a 15 inch Hubcap on a 16 inch Ford Truck. I ended up here because I am looking for the same thing for 14" caps on 15" rims
  16. junkyardjeff
    junkyardjeff
    Ford 3/4 ton trucks and vans in the late 80s had a adapter to use 15 inch wheel covers.
