1955 plymouth rear brake help?
Discussion in 'The Hokey Ass Message Board' started by marq, May 5, 2006.
  1. marq
    marq
    we got a 1955 plymouth and we are trying to get the rear drums off.There seems to be a big nut holding the whole lot on(does not say in shop manual).Anyone know what i should be doing to get this off?help help help...............Marq
  2. 53sled
    53sled
    from KCMO
    remove nut, then use a puller, slide hammer to yank the ***** off (will require cussing). and Bob's your Uncle.
  3. Thumper
    Thumper
    Yep, there is several types of pullers for those...one is a 3 legged deal that is bolted on by the lug nuts with a large screw that pushes against the axle. It has a striking head on it you knock the **** out of with a big *** hammer to appply pressure. Be careful you do not mushroom the end of the axle when doing this by putting the big nut back on the axle until it is flush with the end before using this tool. This helps keep it from mushrooming. Or......they make a tool that is a solid big nut that screws on the end that you bash with a big hammer to jar it loose. Apply generous amounts of penetrating oil before starting removal. Good luck.
  4. marq
    marq
    Are the nuts a left and right threaded deal as we are having real problems getting them off.any more advice would be appreciated.............Marq
  5. blueskies
    blueskies
    from Idaho
    Marq-
    I think the threads for the large nut are the same for both sides. There is a keyway in there, so don't lose the key when the drum comes off. You need a big-*** puller to get the drums off, if they haven't been off in a long time. Be sure to leave the nut on the axle a few turns, so that when the drum busts loose it doesn't fly across the garge or take your head off. The nut will keep it on the axle. They come off with amazing force when they go. You might as well change the axle bearings and seals while you're in there, it'll take another 15 minutes...
    Pete
  6. Bugman
    Bugman
    Both nuts are standard thread, torque spec is something like 200 FT/LB, so they're on really damn tight, plus any rust/corrosion. The first time I had the drums off my '55 Ply, I argued with each side for a few hours trying to get things apart.
    If you don't have a drum/hub puller, and you probably don't, here is the ONLY other way to get the drum off without destroying anything. Loosen the axle nut exactly 1 turn, then put the cotter pin back in. Then drive around the block, turning left top get the left drum loose, right for the right one(it's only recomended to do one at a time BTW). The sideloading on the wheel will cause the drum to pop loose from the tapered axle. once you hear it pop, get back to the garage. If you dodn't hear it pop, check it after every lap around the block. It'll stay loose on the axle because the nut is till there, and you may have to corner pretty hard to get it loose if it's been awhile since it was last removed.
  7. Thumper
    Thumper
    THAT'S the puller I was talking about...!
  8. 302GMC
    302GMC
    from Idaho
    Using a puller similar to Bluesky's (mine has a 7/8'' hex), I tighten it as tight as my air gun will go, then hit the tapered end of the hub with the #3 tip on the torch. Usually pops loose in 10 seconds, seldom have to retighten the puller. Back off the shoes all the way before you start. Be aware the axle shaft end play is adjusted by shims under the backing plate(s), so keep track of where they came from if you do the brngs ...
    302
  9. marq
    marq
    Just like to say thanks guys that was very helpful.I do have a puller as well exactly the same as the one in the photos...............Marq
  10. ezrods
    ezrods
    Make sure you adjust the shoes inward first so they don't catch on the drum. And get the puller that you smack with a sledge hammer.
  11. X38
    X38
    I think after nearly 10 years the OP has probably moved on!
