1965 Ford F100 For Sale Specs Engine: - 390 FE New rings, bearings and gaskets -fresh heads done by extreme cylinder heads with hardened seats and beehive valve springs - lunati cam - cast 4bl intake with new quick fuel 750 carb Transmission: - 3 on the tree - Resurfaced flywheel, New clutch, pressure plate, and throw out bearing - All new u joints and shortened driveshaft Suspension: Mustang II front from JW Rod Garage -Power Rack -New Brakes - 6" c notch rear with axle flip and 3" lowering block - 9" ford rear end that was gone through with 3.89 rear gear Wheels/Tires: - ET G***er wheels up front 15x6 wrapped in Firestone rubber -ET Five Window wheels in the rear 15x10 with Radiar pie crust cheater slicks Misc information: - Hydroboost brake setup - Braided and push lock lines with AN fittings throughout - All new lines throughout - Frame was sandblasted and painted - Underside of truck has been under coated - Redone seat Truck was just finished and still need to have front end aligned and windsheild replaced before pickup Any questions feel free to give me a call 262-370-8321 Located in Milwaukee Wi
