Hot Rods Can I lead this or a Better Idea?
Discussion in 'The Hokey Ass Message Board' started by fasttime, Mar 3, 2015.
  1. fasttime
    fasttime
    The lines of the body and the rear clip door and body are not lining up, and never will. Should I bondo a nice transforming piece? Or lead in a thick piece to join the two? For the right pictures go to post #28, or just enjoy the fun till you get there. Thanks!
      154.3 KB
      134.6 KB
      132.3 KB
      132.3 KB
      134.6 KB
      154.3 KB
  2. Unkl Ian
    Unkl Ian
    Do your pictures relate to your question ?
    Or do they confuse the viewer ?
    Fender1325 likes this.
  3. fasttime
    fasttime
    ummm wow??? New hamb?
  4. fasttime
    fasttime
    Something wierd here......
  5. 57 Fargo
    57 Fargo
    I'm so confused.........
  6. fasttime
    fasttime
  7. fasttime
    fasttime
  8. You'll be ****ed if you lead the doors to the driveshaft yoke, that's for sure
  9. Fender1325
    Fender1325
    Hahah
  10. 57 Fargo
    57 Fargo
    ^^^yup! Definatly want to use bondo between the driveshaft and door, not lead
    tb33anda3rd likes this.
  11. fasttime
    fasttime
  12. Rusty O'Toole
    Rusty O'Toole
    Level it out with body filler. It will last as long as you want it to.
  13. Fender1325
    Fender1325
    Go ahead and weld the oil filter to the driveshaft yolk. Run synthetic and you'll be all set.
  14. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    On a good note, I like the close up of the driveshaft adapter.
  15. fasttime
    fasttime
    New hamb? wtf? I do not know where those old pics came from. trying to post the right pics.......
      132.3 KB
      134.6 KB
      154.3 KB
  16. fasttime
    fasttime
  17. fasttime
    fasttime
    funny ****.........I will keep on trying......
  18. fasttime
    fasttime
    loser to my own thread
      154.3 KB
      134.6 KB
      132.3 KB
  19. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Definition of an insane person. Someone who does the same thing over and over but expects different results.
  20. fasttime
    fasttime
  21. fasttime
    fasttime
    Epic Fail..................Have Fun!
    56don likes this.
  22. Is that closed to open drive shaft conversion?
  23. Thats funny Vicky 31 busted a gut on that one.:D
  24. Kinky6
    Kinky6
    Fasttime,
    Well, if nothing else, let me congratulate you for being able to make use of one of those Stilko filter covers. Do you know the part # for that filter?
    I'd been thinking about cutting down the depth of one of those Stilko cans to make a tach mounting cup. Good luck on your body lines; remember, lead is more traditional than Bondo.........
    K6
  25. tb33anda3rd
    tb33anda3rd
    at least they are right side up. my first pictures were all upside down.
    the only way to save this is describe the pictures you posted.
  26. indyjps
    indyjps
    Can't tell what you're working on, but I'd advise against using bondo on a door edge or door pillar edge. One good bump and you're in trouble. Go for lead if ya got the skills.
  27. Unkl Ian
    Unkl Ian
    Do you drive to work, or bring a lunch ?
  28. fasttime
    fasttime
    body line 001.JPG body line 002.JPG body line 003.JPG 3 weeks later and I may have the right pictures! Soooo, once again.... Can a charactor line be made out of lead to either blend or combine these two different lines? Yes, the rust will be cleaned up and the welds smoothed , no, I will not weld a driveshaft from it to the door, and the Stilko is a gutted swap meet find to cover that Fram tastic filter.
  29. fasttime
    fasttime
  30. Well that wrap around is too low.
    How'd that happen?
    You want to fill it up and carve it back make your own body lines?
    Lead would be better but I bet you can get by with mud as long as the metal isn't moving around, the prep is flawless, quality filler mixed correctly.
