Hot Rods When did Tunnel Rams first come about?
Discussion in 'The Hokey Ass Message Board' started by flatheadpete, Mar 4, 2015.
  1. flatheadpete
    flatheadpete
    from Burton, MI
    I'd like to run a tunnel ram on a small block Chevy and this got me to thinking when they first came to be used. Any ideas?
  2. squirrel
  3. bowie
    bowie
    I've always heard Ralph Ridgeway pioneered the first box type tunnel ram; the "Ridgerunner" intake. The Ramcharger High& mighty was also similar to a tunnel ram. Not quite sure on the dates, would have to dig into the old mags to pin it down
  4. Gotgas
    Gotgas
    from DFW USA
    1959
    volvobrynk and bowie like this.
  5. squirrel
    If you're going to make your own, you can do whatever you want....but if you're going to buy one and call it traditional, you might think twice.
  6. sunbeam
    sunbeam
    The first one I saw was a 63 up Corvette fuele manifold with the top plate replaced with one for carbs.
    pitman likes this.
  7. elba
    elba
    The slant six is a factory horizontal tunnel ram !
    Maverick Daddy likes this.
  8. 49ratfink
    49ratfink
    they actually did make a sideways "tunnel ram" for the slant six. I think it was called Hyperpack.. ?? the carb was 2 feet away from the head
  9. flatheadpete
    flatheadpete
    from Burton, MI
    Totally forgot about the High n Mighty car!! As far as making one....no. I'll probably buy one. If I even get to do this. Anyways, thanks for the quick history lesson.
  10. Larry T
    Larry T
    If you want to know the history of tunnel rams, you might Google Carroll Caudle too. He was working on them around the same time as Ridgeway.
    And there was a pretty good discussion about them here a few years ago.
  11. Andy
    Andy
    The ridge runner ram was being used in 64. I made a dual AFB tunnel ram using a 64 FI manifold in 64. I orderd the parts from Chevy. I used it on my 64 Chevy 11 with 327. I don't think anything else was being used. Eldebrock came out with the TR1 about 65 or 66. BIll Thomas had been using dual air horns on FI units used in road racing. That is what got me to try it with the AFB's.
  12. Larry T
    Larry T
  13. draggin'GTO
    draggin'GTO
    Pontiac would be the first to make a true 'tunnel ram' intake. It appeared on the 1963 13:1 compression 410-HP 421 SD engines, ready to do battle in the 'Stocker Wars'.
    The setup pictured below has the center one-barrel side draft idling carb intact, very rare to see this. The factory soon found it really wasn't needed and blocked off the opening for the center carb with a plate.
    VANDENPLAS likes this.
  14. draggin'GTO
    draggin'GTO
    In all of its naked glory here's a rare reproduction of the 9772128 'bathtub' tunnel ram intake. Later versions of the factory intakes completely eliminated the holes and mounting pad for the center idling carb.
  15. 36 sled
    36 sled
    from colorado
    does a flathead sling shot manifold count ? I think that would be a**** the first
  16. As much as I don't particularly care for tunnel rams (reminds me of the '70s) I would totally ruin one of those. In fact I am going to have to keep this thread just so I can come back for a reminder incase I decide to build one. ;)
    Most people consider the intake on the old Ram Chargers coupe to be a tunnel ram but it is actually credited with being the forerunner of the long ram intakes from the early '60s.
    I am not absolutely sure but I think that the Edelbrock bread basket was the first commercially marketed tunnel ram.
    So hypothetical question, suppose that you built a tunnel ram but with two separate plenums say one for the front 4 and one for the rear 4 cylinders, would it still be a tunnel ram?
  17. flatheadpete
    flatheadpete
    from Burton, MI
    This is what I love about the HAMB....Simple question gets you a whole friggin history lesson. Thanks guys.
  18. draggin'GTO
    draggin'GTO
    Factory installation, 1963 421 Super-Duty Tempest.
    Six Tempest coupes and six Tempest wagons were built with the 421 SD that year, very rare factory race cars.
    Perched on top of the 'Bathtub' tunnel ram were a pair of NASCAR 750 cfm AFB carbs.
    A thing of beauty.
    lawman and squirrel like this.
  19. wheeldog57
    wheeldog57
    phil miller from haverhill, ma sold his design for his breadbox tunnel ram to weiand. i dont know the details or dates but there are a couple examples still in the area and they are primitive looking. i believe the first one has to be the one made for the high and mighty though
  20. Randy Routt
    Randy Routt
    The Hyper pack was a sideways tuned length runner tunnel ram. Clifford had been making them again a few years ago, using Doug Dutra's molds, I shoulda bought one then.
  21. Blue One
    Blue One
    from Alberta
    I can't tell you exactly when they came to be, but I can tell you that they are a race designed manifold and operate very poorly on the street.
    Lots of guys will tell you that they work fine, but it just isn't true.
    They do not work well in the idle to mid range where you do most of your street driving.
    Choose a different manifold, you will be much happier.
    And yes, I do speak from practical experience both on the street and from some dyno experiments.
  22. DDDenny
    55 Chevy hardtop correct, have not heard that name in yeeers, IIRC from Texas.
  23. Larry T
    Larry T
    Yes, Blue and white 55 hardtop that ran Modified Production out of Amarillo.
  24. Shaggy
    Shaggy
    from Sultan, WA
    The early style Crossrams are pretty much that way, m/t put a crossover on his tho. The later crossrams with the removable tops were more of a short version of a crossram
