Technical Bringing back old chrome
Discussion in 'The Hokey Ass Message Board' started by Gerg, Mar 4, 2015.
  1. Gerg
    Gerg
    I have read a ton of threads on chrome and trying to get that old shine back. This is my method after some testing.
    Step one soak a piece of paper towel in CLR 5 to 10 minutes on the piece of chrome you are working on. In this case I chose a big *** bumper because I was testing other methods and working on this so i needed something large.
    After it soaks for that couple of minutes on the rusty chrome I have been using a sharp razor blade and s****ing all the scale rust off of the chrome.
    After s****ing it's onto the 0000 steel wool and start working it over. I am doing this all by hand other then the final buff.
    I am not set on a compound yet I am testing some turtle chrome polish and I have some wizard on order.
    The test piece removal just to give you an idea of the condition of the car it was picked off of in the boneyard.
    Oldsmobucket likes this.
  2. Gerg
    Gerg
    Before
    This is the after.
  3. Gerg
    Gerg
  4. Gerg
    Gerg
    The proof is in the pictures. I don't know how long the results will last. Hopefully long enough for my friend Terry to save up some cash to get it rechromed.
    The top of this picture was the better of the two when i started. I have not finished the bottom one yet still more work to go.
  5. Gerg
    Gerg
    Here is a piece currently soaking in the CLR
  6. Gerg
    Gerg
    right after the soak.
    This is after a lot of scrubbing with 0000 steel wool and polishing with the chrome polish
  7. indyjps
    indyjps
    Doesn't the steel wool scratch the chrome? I've seen threads on using balled up aluminum foil but have yet to try it.
  8. Coca cola and tin foil works really good too !!!
    Ball up the tinfoil pour the coca cola on it
    and rub the rust away and watch it shine
  9. Gerg
    Gerg
    That is why i am using 0000 steel wool there is different grades and that is the finest. It has not scratched the chrome. I didn't get very good results with aluminum foil it took even more scrubbing. What you see here is what i have found that works best so far. Of course I am open to suggestions but I have tried a couple different ways.
  10. did you try it with the coca cola ??
  11. Gerg
    Gerg
    Tried the coca cola what I need to do is try soaking it like i am with the CLR and see how that compares. Pouring it on doesn't give **** for results compared to soaking it. Unfortunately I used my last can of coke in testing.
    patmanta likes this.
  12. Stevie Nash
    Stevie Nash
    I've had good luck with the fine steel wool. If the chrome can't take that then it's too far gone anyway....
  13. slammed
    slammed
  14. x-shift
    x-shift
    Nice work Gerg! I have found that when polishing, buy whatever has the highest ammonia content. If the fumes almost make you p*** out, you got the right one. Blue Magic used to be really strong, but I've heard they cut back. Mr. Metal is pretty good, too. Good luck!
  15. Frankie47
    Frankie47
    from omaha ne.
    Damn Slammed...I looked forward to your last avatar every day...now it's fat Elvis ball sack camel toe...ack!
    shivasdad and Maverick Daddy like this.
  16. rfraze
    rfraze
    Try Simple Green and 0000 steel wool. Spray it right on the steel wool and rub away the rust and corrosion. Works great. Then go to your polishing steps.
  17. chopolds
    chopolds
    from howell, nj
    Whatever you do, the chrome is still shot. Chrome does not rust. It is the steel underneath that does. When the chrome coating is gone, the steel under it rusts, just like paint. So unfortunately, it is not a fix and will not last. And it doesn't look anywhere near as good as un-damaged chrome.
    Just so you know, not trying to rain on your parade. Great fix for driver quality stuff, but if you repaint the car, it will look poorly next to the nice paint.
    i.rant and belair like this.
  18. Sounds like work I just use an SOS pad and some water and elbo grease. :D
    But if it works for you I'm good with it. Thanks for posting. ;) :cool:
    oldcars.acadia and low budget like this.
  19. woodhawg
    woodhawg
    CLR is good stuff. What percentage are you mixing?
  20. Gerg
    Gerg
    This is not a permanent fix. I am well aware of that. I am also not blind I know it is not as good looking as fresh chrome. This is just a way of cleaning up the old stuff until he can afford to get it re-chromed. Driver quality is good enough for right now for the car we are working on.
  21. Tim
    Tim
    from KCMO
    Yeah he literally said I hope it last long enough to save up the money to replace them.
    Anyhow, what's CLR?
  22. Mark T
    Mark T
    Try soaking your chrome in wood bleach (oxalic acid) the stuff works great, I buy mine at the local hardware store.
  23. patmanta
    patmanta
    from Woburn, MA
  24. I've had the best results on poor chrome by using a sewn cotton buff and tripoli buffing compound with a power buffer. The compound isn't aggressive enough to remove the chrome, it's finer than any steel wool so it doesn't dull the chrome, but takes off rust/oxidation like gangbusters. Don't be too heavy-handed where the chrome is 'good', but if you bear down in the pitted areas it can even get the rust out of the pits. I never use steel wool, it dulls the finish too much. Damaged chrome is damaged chrome, but I've 'brought back' some pretty nasty parts to where they can p*** the 'ten foot' test...
  25. David Gersic
    David Gersic
    from DeKalb, IL
    I've had good luck with Lightning (http://lightningstrip.us/rust.htm) and Scotchbrite green pads. As others already said, the damage is done, and nothing will be perfect, but this stuff works pretty well.
  26. Rusty O'Toole
    Rusty O'Toole
    I use copper scrubbing pads instead of steel wool, they don't scratch.
  27. low budget
    low budget
    from Central Ky
    I also like SOS pads.
  28. Squablow
    Squablow
    Looks good! Put some good wax on everything once it's all done, will help keep it from rusting right away again. If Wabs keeps it clean, it'll look nice for a good long while.
    People need to take note and at least try their best to polish up old chrome before they go painting over it which almost always looks like dog ****.
    slammed likes this.
  29. Mike Miller
    Mike Miller
    I buff mine by hand with fine steel wool, pay no attention 2014_0917.JPG 2014_1207(009).JPG to the air cleaner, it's new.
  30. Gerg
    Gerg
    I got some polish wizards turbo cut and colonel br***y. The br***y is a touch more co**** so i am using that first then finishing up with the wizards. I will get some more pictures going hopefully tonight. I want to show you guys the bumper so far it's about 1/4th done but thats not good enough for a comparison shot yet.
