For Sale: Lakeroadster's 1965 C10 Hot Rod Truck
Discussion in 'Cars For Sale' started by lakeroadster, Feb 24, 2015.
  1. lakeroadster
    lakeroadster
    from *
    City: Denver
    State: Colorado
    Price: 9,500.00
    For Sale
    1965 Chevrolet C10 Pickup. Short Wheel Base Step Side
    I have do***ented the changes I have made to the ole Orange Crate in a "Build Thread". For more information check it out at
    Build Thread http://talk.cl***icparts.com/showthread.php?t=13928
    Video
    This truck steers and stops like a mid 1960's truck. If you want a true old school hot rod truck, like the one's you remember from the 1960's look closer at this one. It has "armstrong" steering, "legstrong" brakes and "55 mph wind wing" ventilation. If you've never driven a vehicle without power steering or without power disc brakes this truck likely isn't for you.
    Truck has an aftermarket cam (loaping idle) & long tube headers, installed by the previous owner. I installed 2-1/2" diameter gl*** pack mufflers and dual exhausts that run all the way to the back of the truck. Sounds retro 1960 - 1970 Hot Rod...
    I bought this truck in Aug. 2008. The drive train is pretty much as it was when I purchased it. The engine and transmission are not original to the truck and I have no idea how many miles are on the drivetrain, or on the truck. The only major drivetrain components I changed are new heavy duty CPP 4" drop rear coil springs and updated the wheels to aluminum slots and changed the tires to Goodyear Wrangler Silent Armor 33X12.50R15LT rear and P235/75R15 front.
    The bed I widened 4 inches by cutting it down the center. I removed the stock gas tank from the cab and installed a new "Tanks, Inc." 1949 Chevy p***enger car tank in the rear frame of the truck. Truck has new 1964 Impala rear tail lights, new GM Suburban third brake light, custom welded steel spare tire carrier, 1967 Camaro Dash, new low back bucket seats, 1970's Blazer floor console, new Lokar floor mount hand brake, new Hurst '57 Chevy 4-speed floor shifter, new Auto Meter Gauges (speedometer, tachometer, oil pressure, water temperature, voltmeter, fuel level, vacuum).
    It has faux patina paint that I applied right over the top of the 50 years of dents and dings that it wears proudly. If you are wanting a clean, straight, ready to paint truck, or a show quality paint job this isn't the truck for you. The cab of the truck has had bodywork and a repaint many years ago, a long time before I got the truck. Front lower fenders will need lower patch panels, which I have but have not installed. Doors will also need some lower outer panel repairs, I have one patch panel for that also. The p***enger side cab corner would need some work too. But as an old Hot Rod truck it's lookin good and is good to go as is.
    The truck, as it currently sits, has more than $10,000 in new purchased parts. This is above and beyond the original 2008 purchase price and all my labor to make it what it is today.
    EpicRider likes this.
  2. lakeroadster
    lakeroadster
    from *
    Sold! Headed to New Zealand. Good Buy Old Friend, Have Fun!
