chevy ll 4 banger ?
Discussion in 'The Hokey Ass Message Board' started by lilbill, Nov 24, 2006.
  1. dago_red
    dago_red
    from NW
    young olds- I took a look at your chevy 2 a while ago when you were advertising it- decided to hang onto it?
  2. Truckedup
    Truckedup
    As said before there's no vibration damper on the 153, just a small hub for the pulley to bolt onto.
    I swapped a 153 into an O/T 47 CJ2A Jeep.With stock 5.13 gears the engine is always turning high rpm and runs very smooth with just the stock pulley....The stock Jeep Go Devil engine didn't have any damper either...
  3. young olds
    young olds
    I believe the ad is still up, its my daily driver so I like to keep it running good.
  4. RoddyB34
    RoddyB34
    Has any one got a Chevy 11 engine coupled to a 39 type trans to closed drive rear in a 28 A,,does the rear of the head clear the firewall without mods ?,,,i can see in a few pics the engines are fairly close,,,,
  5. chiliman
    chiliman
    from liberty mo
    Gona put the merkcrusier version in,my A usemal
    The 48 to 52 truck hogshead get small block chevy adapter although I'm gona put 84 f 1oo 4speed over drive with open drive havde day a
    Posted using the Fullo Custom H.A.M.B. App!rsion in
    ELloningbless
  6. 1934coupe
    1934coupe
    Had this 153" Nova motor and air cooled powerglide in my 36 Willys sedan. Drove the **** out of it and was very happy with it. Sold it around 1979 and saw it again in the street rod nats around 88 in Columbus. Guy that now owned it loved it.
    Pat
  7. chiliman
    chiliman
    from liberty mo
    Yea they have tough lower end should be plenty of umpp for a 30 rodster picup going to the big swap meet in witcha ks in couple weeks will pick up a few items
  8. Just picked up a Mercruiser 140 head and finned valve cover/valley cover for my 153... wondering if I should have grabbed the cam (the lifters looked VERY clean with just a little wear).
  9. chiliman
    chiliman
    from liberty mo
    Yea better go back and get it
  10. cheesegrater
    cheesegrater
    from california
    Its gets into it costs to be different a friend of mine built one of these a few years ago & said he could have built 2 small blocks for what the 4 cyl cost so check it out
  11. chiliman
    chiliman
    from liberty mo
    Yea I wanted to do a full dress b motor 4 grand for miller. I t hink merkcruiser might be a bit chepper have a blessed day
  12. Thanks chiliman- anything else I should grab?
  13. chiliman
    chiliman
    from liberty mo
    1929Dan I need some more in formation page 11 post 203 to make the mounts they are missing some of the measurerments on the with and lenth hole placement and thickness of metal what frame mounts did you use? any pic or measure ments would be help full thanks
  14. Six Ball
    Six Ball
    from Nevada
    Here is the intake/exhaust set up I'm working on for the 153 thats going in my '26 Chevy roadster. There is a little cutting,welding, and port fitting to do but not really much as compared to building from scratch. It looks cool too!
    29EHV8 likes this.
  15. chiliman
    chiliman
    from liberty mo
    Thanks going to call ppatrcks tomorrow see if they have headers for 181
  16. Six Ball
    Six Ball
    from Nevada
    This one is 1/2 of a set of Fenton Black Widow headers for an early small block Chevy, with front mounts. I've been thinking about this for years but couldn't find one side. Patrick happened to have one from a set that was broken in shipping.
  17. jt1949
    jt1949
    Does anyone know how far you can bore a 153 out... I ended up with a motor .30 over. Wondered how much meat is left on it?
  18. Six Ball
    Six Ball
    from Nevada
    I think they would be like the 6s of the same family and be safe to .060 though some blocks can go more.
  19. jt1949
    jt1949
    Thanks six ball
  20. Six Ball
    Six Ball
    from Nevada
    You are welcome. What is yours going in?
  21. jt1949
    jt1949
    1936 ford pickup.
  22. Six Ball
    Six Ball
    from Nevada
    That will be very interesting. With the T-5 it should be an great driver.
  23. 28hiboy
    28hiboy
    from Milton, Fl
    You can put a 250 ci balancer on the 153 ci motor. I did.
  24. pdq67
    pdq67
    I haven't read this whole thing so if I repost, please disregard.
    I want to say that "Langdons" is into Chevy II 4-bangers.
    pdq67
  25. 1934coupe
    1934coupe
    I disagree, it didn't even cost me as much as a SBC for the Chevy Nova motor in my Willys, pistons are same as SBC, cam is same price w/ 8 less lifters and valve springs, intake may be a little more, carb is same price, header is comparable but you only get one. Balancing a 4 cyl. is cheaper and to top it off you only pay for 4 spark plugs. I love these motors.
    Pat
  26. Six Ball
    Six Ball
    from Nevada
    Mine is costing less than a V8 would have and if I decide to build more of them they will be even cheaper because of things I have learned.
  27. chiliman
    chiliman
    from liberty mo
    Hey guys putting mercruser 140 in A pickup using vegA box any feed back or pictures using square back spendles thanks
  28. jt1949
    jt1949
    1936 pickup, 153 chevy, s10 5sp s10 2wd rearend
  29. jt1949
    jt1949
    525 saginaw box
  30. chiliman
    chiliman
    from liberty mo
    Thanks just tring to peace it all together in mind any one doning it to a A thanks
