Customs Finished trunks. How'd you do yours? Let's see the result!
Discussion in 'The Hokey Ass Message Board' started by flypa38, Mar 3, 2015.
  1. flypa38
    flypa38
    Man, I like how the finished trunks in some of my favorite customs look. Just wondering how they're made, what they're made of, and mostly how do they attach to the body? I sure wouldn't mind seeing what you guys have built too! Lots of skills and knowledge here.
    Here's an example from another thread in case you aren't sure what I'm referring to:
  2. Bam.inc
    Bam.inc
    from KS
    Good topic. Subscribed to see what comes up.
    Any past links to attach to thread?
    I think materials, attachment,
    pics under construction & finished are beneficial?
  3. manyolcars
    manyolcars
    I finished the trunk of my Model A coupe with a dropped floor
    Bam.inc likes this.
  4. Tools in the trunk like a display is ,,, a,,,,well,,,, kinda silly no?
  5. I like how her trunks attach to her body....:D
    Whoops, you meant the car. :oops:
    I got confused, down here we call it a boot.;)
    The tools on display are cool in a custom, but maybe not in a bad*** hot rod.
    Good idea for a thread, I've seen some cool trunks, usually the upholstery would match the car interior.
  6. 56premiere
    56premiere
    DSCN0070.JPG DSCN0071.JPG DSCN0074.JPG DSCN0070.JPG DSCN0071.JPG DSCN0074.JPG Lets see if I can get this to work
    LOU WELLS likes this.
  7. aaggie
    aaggie
    Trunks are easy compared to the interior of the ride. Most trunks can be finished with flat panels cut from Masonite and covered with glued on Vinyl. Velcro strips on the back of the panel and the other half of the Velcro glued to the sheet metal. Same with the floor, carpet glued to a sheet of Masonite cut out to cover the trunk floor.
  8. Tim
    Tim
    from KCMO
    46steel any more shots of that? Do you have your spare behind that panel? I've been planing out how we are going to ours in the next few months
  9. ImageUploadedByH.A.M.B.1425482119.320183.jpg 47 Ford-Simple panels that are held in place with Velcro
  10. Tim
    Tim
    from KCMO
    Velcro seems like a great idea, a lot easier than drilling hole's and setting up plastic barbs to hold it all together!
  11. Tim
    Tim
    from KCMO
    Cool thanks man
  12. young'n'poor
    young'n'poor
    from Anoka. MN
    Cool ideas. I'm surprised more custom guys haven't chimed in with ideas and oictures
    LOU WELLS and Asphalt Angel like this.
  14. flypa38
    flypa38
    Agree it's sort of hokey but that's what was done back then and that's what I'd like to eventually re create.
    Just a note on the velcro. Great idea but making it stick is a problem when used alone. Velcro is used extensively on aircraft interiors and we use 3m 1300L gasket cement on everything velcro to make it stay. A real thin coat on the velcro and what you're sticking it to then stick it on when the cement is almost dry.
    As far as the display tools, any idea what the straps are made of to keep the tools in place?
  15. 911 steve
    911 steve
    from nebraska
    my .02 as a retired firefighter, move your extinguisher to your p***enger compartment. mine is attached crosswise in front of my seat. EASY ACCESSABILITY IS MOST IMPORTANT, SECONDS COUNT
  16. timwhit
    timwhit
    Up here we call it booty...oh, you were talking about the car.
    kiwijeff likes this.
  17. A trunk with tools on display - hummm
    I suppose the tools are polished
    (aka not used)
    I suppose this is a trailer queen
    (Aka not used)
    I suppose the tools aren't needed
    (Aka not used)
    I suppose actually grabbing a tool off the display with grubby fingers would not ever be done for fear of getting the backing dirty.
    (Aka not used)
    So the attachment could be semi permanent since they won't be coming off for use, falling off getting loaded on the trailer, or going down the road.
    It's a cod piece for the trunk.
  18. Vintage Pipe
    Vintage Pipe
    from Greer, SC.
    The trunk is one place on a car most people don't, pay any attention too. However, my driver carries coolers, tents and chairs. More to be done to it soon. Have some progress photos, however, they need to be resized first. trunk.jpg
  19. flux capacitor
    flux capacitor
    53 150 more door , vynil covered abs formed panels easily removed with a single phillips screw. Battery now lives in tire well. Also have easily accessible insulated 12v power & ground provisions n a pwr antenna. Flux. image.jpg
  20. chevy57dude
    chevy57dude
    Guess all the show cars that were scored on the amount of modifications helped the trend start. A clean trunk is great, but "prop'' tools and oil cans just look like poser stuff. Gotta be careful not to step into street rodder territory!
  21. vtwhead
    vtwhead
    I have been working on finishing the trunk in my 64 BelAir . Still more to do but the winter has chased me out of the garage. Here is what I have finished so far. The black cord is the battery tender feed for the winter.
  22. T
    That's one of two, the other one is attached to the back of the seat, not the quickest place either but I'm at a real shortage for space inside, I do appreciate the advice and maybe I can relocate it like you said cross ways just behind the shifter.
  23. i.rant
    i.rant
    image.jpg image.jpg image.jpg image.jpg Here's mine in my 40
  24. tedley
    tedley
    from canada
