Will a 53-54 Chevy column and steering gear bolt into a 50 Chevy?
Discussion in 'The Hokey Ass Message Board' started by RATRODCHEVY, Aug 21, 2013.
  1. RATRODCHEVY
    RATRODCHEVY
    The steering gear in my 50 is tired. I was thinking of rebuilding it, but someone told me the later 53-54 boxes are better (ball bearings and recirculating ball v. worm and sector) Has anyone done his swap? Any info would be appreciated. I'm not looking to replace the front clip, or MII. I want to keep the stock suspension and steering. Thanks
  2. happy hoppy
    happy hoppy
    I put a 1954 chevy steering box in my 1950 chevy, it bolts up.
  3. 302GMC
    302GMC
    from Idaho
    Grab the brakes & rear axle, too. Everything under a '54 is an improvement & it all bolts in.
  4. Hnstray
    Hnstray
    from Quincy, IL
    I expect the '54 will fit the'50...... Ball bearings vs bushing I can believe..........but I seriously question that "recirculating ball" claim. Boxes with that feature are typically much bulkier and from my recollection, the '54 boxes look pretty much the same as '49 up.
    In any case, a box in better condition would be worth the effort to change it.
  5. 33Tudor
    33Tudor
    Yes it will. Some years ago, my neighbor was restoring a 49 fleetline and wanted to convert it to automatic, making it look stock. We couldn't find a 50 to use the column, so we used everything(trans, column, indicator)from a 54 and it bolted right in.
  6. 56sedandelivery
    56sedandelivery
    The box should have "better" gears or bearings or some such, plus, the column is shorter to give you more room, and you get integral turn signals. That's what I remeber anyway. And yes, it's a bolt-in. Butch/56sedandelivery.
  7. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Its not recirculating ball and the only difference in the bearings is the sector shaft has a roller bearing and not a bushing like the '50. It also has a slower ratio which makes it easier to steer. I replaced the gear box in my '50 sedan delivery with a 54 a while back and am real pleased with the results.
    Oh and you inherit self canceling turn signals in the process.
    Slow down likes this.
  8. 100% bolt in, I did it with mine.
  9. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
  10. RATRODCHEVY
    RATRODCHEVY
    Cool. Thanks everyone for the info
  11. King Karl
    King Karl
    from N.C.
    I know that this is an old thread (for you thread police) but does anyone know how much shorter a 54 column is than a 50?
  12. tkmark
    tkmark
    Ask over on Chevy Talk, someone will know there. I switched to a 54 column in my 50 Fleetline and it works *****in. I did use my 50 shift arm ***y. and had to drill new holes in the column to accept it. only about an inch or so away from the original holes.
  13. King Karl
    King Karl
    from N.C.
    Was there a noticeable difference in the distance to the steering wheel after the switch?
  14. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    None that I noticed.
  15. tkmark
    tkmark
    I didn't notice any either.
  16. Rocky
    Rocky
    Classified Editor
    I also used the 53-54 column and gear in my 50 delivery......huge difference!
    I used an early 70s chevy van column [non tilt] after doing a little grinding on the original 50 column drop. I think the van column was 1/8th to 1/4 inch bigger. I cut the 53 steering shaft off about 8 inches above the box and tapped a seal in the top to keep dirt out of the box.....welded a rag joint receiver to the 53 shaft, using a cold, wet rag to keep heat out of the box. Used a new rag jiont bettween the 53 box and the van column to take some of the vibration out of the wheel and to help with a teeny misalignment ....worked great
  17. 56sedandelivery
    56sedandelivery
    53-54 are about 1 inch shorter, so there's a little more "belly room" with the steering wheel if you have that problem. And, you get built in turn signals. I am Butch/56sedandelivery.
