Projects Chevy Custom Grill
Discussion in 'Traditional Customs' started by Andreas Stremitzer, Mar 6, 2015.
  1. Andreas Stremitzer
    Andreas Stremitzer
    Hi,
    I’m actually working to bring Richard Zadroga's custom car which was made in the 1950’s back to its original beauty.
    Unfortunately the original grill is gone and I'm trying to rebuilt it.
    Until now I figured out that it was made out of parts from the 57 Corvette grill while using 23 teeth and they look like all the same size and pointing straight ahead.
    As I'm not familiar with the Corvette grill, does anyone know which teeth I should use (only 23 center teeth, or 1 center tooth and 22 teeth which are mounted normally left and right from the center tooth)?
    Thanks for your help
    Andy
    Maverick Daddy likes this.
  2. fatty mcguire
    fatty mcguire
    good buy, was hoping to stay local, gl with it
  3. atomickustom
    atomickustom
    You'd need one center tooth and 22 "next to center" teeth. The bar curves and a middle tooth wont face straight ahead when mounted in the other positions.
    Looking really close at the photo you posted I'd say there are actually all the stock sizes of teeth on there, but with 10 extra "middle" teeth added between them. You can see how much smaller the end tooth is compared to some of the others.
    And I'm pretty sure I was wrong on your other thread when I suggested the horizontal bar was lengthened.
    It looks to me like you just need a complete grille and 10 extra teeth.
    It has been 12 years since I ordered mine so I can't remember if there are three or four different size teeth.
    Shop it around - I bought my grille from a Corvette resto place that had the best price and sold the teeth separately as well.
    Looking forward to seeing your progress on such a cool car!
  4. CHOPMERC
    CHOPMERC
    Also, I recall you asking about the flat white lenses in the 59 caddy taillights being used as parking lights.
    If you haven't yet gotten the answer, those lenses are stock to the ***embly. They are in there behind the red bullets. Originals shouldn't be too hard to find, otherwise I'm pretty sure repops are available.
    Good luck with the resto, it's a great old custom.
  5. Andreas Stremitzer
    Andreas Stremitzer
    Hello Dave,
    thanks for your reply. As I'm trying to find out as much as possible about this car I also think that originally a 13 teeth grill was used with 10 extra middle teeth.
    I found a picture here at one threat with a similar grill, but only 17 teeth used. I have tried to contact the owner and I will keep you updated.
    @CHOPMERC Thanks for your help on the 59 caddy tail lights which I will use as parking an signal lights. Thanks to Rik I found out that this lenses are called "tail light diffuser" and as you mentioned they are mounted behind the red bullets.
    It's fantastic how things come together with the help of this Forum!
    Many thanks to all of you and I will keep you updated on this project.
    Andy
  6. Mr48chev
    Stock 57 grill has 13 teeth and put one in each space on each side and you add ten and have 23.
    Some interesting info here http://www.grilleteethusa.com/
  7. Andreas Stremitzer
    Andreas Stremitzer
    Thanks Mr48chev,
    that's an interesting story about the manufacturing process! If have to get in contact with Corvette Central's to see if they also sell single teeth.
    regards Andy
  8. atomickustom
    atomickustom
    Did some measuring today. The two end teeth are shortest, about 6.25 inches. The next two teeth are about 6.5 inches. The next two are around 6.75 inches. The rest, including the center tooth, appear to be all the same length, about 7 inches.
    Measures are all approximate because it's hard to get to mine with the tape measure. ImageUploadedByH.A.M.B.1425836215.820139.jpg ImageUploadedByH.A.M.B.1425836233.088174.jpg
  9. atomickustom
    atomickustom
    I believe I bought mine from Corvette Central. They had the best price at the time and they did sell individual teeth.
