Technical *** March 2015 Banger meet - are you ready for spring?***
Discussion in 'Traditional Hot Rods' started by Jiminy, Mar 1, 2015.
  1. 62pan
    62pan
    Invest in Jim Brierley's book "4-Bangers and me" Well worth the money. It will answer all your questions. Jim is on the HAMB but unsure of his handle.
    HotRodMicky likes this.
  2. gwhite
    gwhite
    SUPER MODERATOR
    First question I'd ask is how committed are you to a late 30's - 40's hop up? (As in, how period-correct are you wanting to make it?)
  3. jimb4e4@gmail.com will get you there. I'm going to use a J Brierley Winfield SU1R regrind in my street build.
  4. nailheadroadster
    nailheadroadster
    Great question, thank you for taking the time to ***ist!
    I would like it to appear vintage to the casual observer. The guys that participate on this monthly thread would most likely pick it apart.
    I will be using an alternator to get 12 volts, but I have NO interest in wrapping my radiator hoses in faux braided stainless with red and blue collars. LOL
    I love the look of lacquered cloth spark plug wires and the stock Model A radiator hose clamps. It will NOT have an electric fan or air conditioning.
    It is dropped with a 33 front axle, 32 spindles and perches and a T spring out back with blackwall Firestones and 35 Ford wires all around.
    So... How committed am I??? Ummm... kinda I guess, but Im not opposed to using new parts as long as I can make em look like they belong. Does that make sense?
  5. Along the same lines, how many $$$' s and how much time are you willing to invest in getting the parts. It has taken me 6 months to locate a Winfield head, a Burns dual down draft and a pair of Stromberg 81's and many$$$'s. I have lots of want ads everywhere looking for those specific pieces and getting difficult to find. Easier to go prewar looking then correct with the reproduction parts available.
  6. waxhead
    waxhead
    from West Oz
    I will be using an alternator to get 12 volts, but I have NO interest in wrapping my radiator hoses in faux braided stainless with red and blue collars. LOL[/QUOTE]
    What alternator are you planning on using?? Power master have recently released alternators that look like original Model A generators, but are 12 volt alternators (they also have a 6 volt model). I have ordered one that is currently on it's way to Australia.
    http://www.summitracing.com/int/parts/pwm-82001
  7. nailheadroadster
    nailheadroadster
    As far as money... I know the parts are not going to be cheap, but I don't feel that I need an original Winfield yellow head, intake and carbs to putt around. Repop stuff is ok.
    I'm really goin back and forth on the intake.... the dual downdrafts look the best to me, but I'm sure with the stock engine two 81s would be too much. And, I have a friend in the local model A club that rebuilds the Zenith carbs so getting another one for a dual updraft would be easiest and cheaper.
  8. nailheadroadster
    nailheadroadster
    I had no idea! Thank you sir!
  9. Bluto
    Bluto
    Time to drag out the "float-less" carb photos again
    These being without floats will mount in any direction The sprung loaded door on the side is for backfire pressure relief
    Jet96 and gwhite like this.
  10. gwhite
    gwhite
    SUPER MODERATOR
    Very cool! Stan Howe had one mounted on a Model T at one point...don't know if he ever got it running. Any idea how much they flow?
  11. Bluto
    Bluto
    The manifold is undrilled
    I have no info. Like most things I have found these at a swap meet years ago
    We moved 11 40 ft containers of this kind of junk to Poland with us..........
  12. Question is, Jim- how many have you emptied :D?
  13. Bluto
    Bluto
    You don't own sea freight containers......... so they are all empty as soon as they came.
    We have a new building for storage 5000ft and a 5 year lease. It';s the nicest building we've ever had
    This town is 26,000 people..... there are huge new buildings and also damp Communist concrete builds
    medium buildings are near impossible to find
    It's stacked to the rafters!
  14. ejay$
    ejay$
    [​IMG] Quick pic I took in my one road hometown.
  15. gwhite
    gwhite
    SUPER MODERATOR
    Freaking cool! 1917-ish Willys? Looks like an A ch***is/drivetrain. Would love to see more!!
  16. ejay$
    ejay$
    1914 Maxwell on A ch***is/drivetrain. Soon to have serious chopped top, have great ideas thanks to MrModelT, blk wall 21s, Thompson finned aluminum head & full interior. [​IMG] [​IMG]
    Leon Sandcastle likes this.
  17. Leon Sandcastle
    Leon Sandcastle
    Like the car, would love to see a build thread!
  18. Phred
    Phred
    from IL
    UPDATE: Heated Carb Riser
    I threatened to report after last month's post...
    I have run the car for a couple days in 15*F - 20*F temps and can report no frost on the intake manifold and that the car does run much better in the cold, car will now run without choke when warmed up. Prior to installation, just the opposite, frost on manifold and poor running. Next step is to replace the rubber hoses with steel tubing to tidy things up.
    SJR likes this.
  19. like this? :p brrrrr.jpg
  20. orangeamcs
    orangeamcs
    Next project for my 29 is to install the b motor and trans I just purchased. As far as I can tell I need the kit that mounts the a pedals to the b trans. Also think I need the front b motor mount kit and float a motor rear mount kit from berts model a. Am I on right track here? If there is a simpler or mode traditional way to do it I'm listening.
    Would really like to do it with a 32 k member or f1 and do the hydraulic brake route all at one time but just want to have it up and running so I can enjoy it. That's a project for next year
  21. 5280A2
    5280A2
    Two advantages of using the Model A spring-loaded yoke are that you retain the three point mounting that allows for frame twist without breaking mounting brackets or the ears on the flywheel housing, and secondly it allows for up and down adjustment to align the ratchet on the crank pulley to the crank bearing on the front cross member. That allows you to retain the use of your hand crank if you want to use it. As a long time Model A guy I prefer to use the hand crank and timing pin to find TDC for setting the timing.
    Fly'n Kolors likes this.
  22. orangeamcs
    orangeamcs
    What rear mount kit are you using 5280a2?
  23. 5280A2
    5280A2
    I made the rear mounts from 3-inch angle and V8 biscuits. If I was going to do it again I would change the design to mount the angle in the frame with the leg for the biscuit at the bottom of the mount instead of the top. My design caused some interference with the clutch pedal on the driver's side which I had to resolve with a shorter arm on the throwout shaft to reduce the amount the clutch pedal needed to move to release the clutch. That combined with some hacking away of the mount got me the pedal travel I needed. I also fabricated the pedal mounts to follow the ones available from Cling's and others, but I couldn't find any pictures of that. They bolt to the top of the transmission and are braced from the end of the pedal shaft back to the flywheel housing. Unless you really like making stuff, the float-a motors from Bert's for putting a B in an A are hard to beat.
    CrazyUncleHarry likes this.
  24. ebtm3
    ebtm3
  25. ejay$
    ejay$
    [​IMG] One more piece to the puzzle! I'll have to shave a small portion of the fins as I'm running original A rods (timing)
  26. gwhite
    gwhite
    SUPER MODERATOR
    Cool! Throw a B distributor on it and don't worry about it :)
  27. briphaeton
    briphaeton
    from cal
    I'm almost done building my full pressure A block and considering doing away with the oil return tube.
    Is it really needed with a full pressured Block? The tube infers with the other oil lines. The only oil getting to the valve chamber well be from the pressure relief valve and should be plenty.
    Thank for your opinions.
    Brian
      135.1 KB
  28. 5280A2
    5280A2
    If your crankshaft is drilled for pressure to the rods I believe you have more flexibility with getting oil from the valve chamber to the pan. One thing to think about is how much oil will it will take to fill up the valve chamber to the point where it will drain back into the pan. Without the return pipe the chamber will fill until it runs through the opening behind the cam gear so there will be more oil up there than would be the case with the pipe. If you keep your dipper tray you now have a couple of quarts of oil tied up where your pump can't get it, especially when you're turning right and the oil is climbing the side of the pan away from your oil pump.
    In my system I pressurized the mains, but still have splash oiling for the rods so I run a pressurized supply that dumps oil into the dipper tray right behind the cam gear. I also drilled two 3/4-inch drain back holes through the floor of the valve chamber to get oil from the relief valve back into the dipper tray as fast as possible without the exterior pipe. The Model B blocks had two drain back holes which I copied when I built my Model A system. The picture shows the front one between cylinders 1 and 2. There's another one in the same location between 3 and 4. Holes were drilled from the crankcase into the chamber, first with a pilot drill, then with a hole saw to final size.
  29. colinsmithson
    colinsmithson
    You will be fine with out the oil return pipe most pressure system do not need it
    in fact it is or was the norm to the point that 01546 oil block off.jpg most A model parts suppliers sale block off plate
