The cut and paste is from the sellers xBay(not mine) Buy It Now ad. Better act quick or it may be gone - or NOT. I believe this car started out as a tiny 1937-1955 Fiat 500 or Topolino ("little mouse" in Italian). It was later extensively modified and became a mid-engine sports car with a custom fabricated steel body. The Fiat 500 was a front engine car with rear wheel drive. It had a 4 cylinder 569cc water cooled engine mounted in the front. The radiator was located behind the engine. The crank pulley at the front of the engine had a belt running up to a generator that was on top of the cylinder head. The back of the generator had a shaft sticking out that the radiator cooling fan was mounted on Use a Packard grille and you can't go wrong with a Custom?
Looks like someone forgot to neuter their Karmann Ghia and then a *****Metropolitan got in the back yard.
It needs a little something something, and a lot of something else. I wouldn't mind owning it, and it could be fun. I preferes it over the over the late model OT truck. [emoji12][emoji41]
