Projects Recreating the jesse lopez coupe
Discussion in 'Traditional Customs' started by jivin jer, Aug 18, 2012.
  1. jivin jer
    jivin jer
    001 (2).JPG Unfortunately the original X member is long gone. Then I realized that I probably better get another one and do the cut/flatten deal. After seeing how heavy and bulky it was I then called Jesse and desided that I would do it Jesse's way. I can use this to get the correct size hole for the spring pack.
  2. bigbore
    bigbore
    Here is my new rear crossmember
  3. jivin jer
    jivin jer
  4. rob-redm
    rob-redm
    pretty snazzy there Jer !
  5. jivin jer
    jivin jer
    The jack that came with this lift is very handy. 002 (2).JPG 003.JPG 003.JPG
    jocktherock likes this.
  6. jocktherock
    jocktherock
    from Sweden
    ****ual & cool angel of picture of an georgeus Kustom car.
  7. Looks like the car just took a **** and left some toiletpaper hanging out of it's pants. :D
    Cooon and loudbang like this.
  8. rob-redm
    rob-redm
    really ??? say something a worth damn , than the B.S. above... not needed...
  9. jivin jer
    jivin jer
    Here's the U bolt problem with the fix, twenty bucks, while I waited. 005.JPG
  10. MUNDSTER
    MUNDSTER
    Nice! What a bargain!
  11. jivin jer
    jivin jer
    Like the lowered seat, I'm dealing with fractions of inches. I don't think I have the luxury of this much room for the suspension snubber. 002 (6).JPG 002.JPG
  12. Peanut 1959
    Peanut 1959
    $#!+ is getting serious, here! :)
  13. drdave
    drdave
    I'm guessing you are going to have to notch the frame?
  14. MUNDSTER
    MUNDSTER
    On my 33 ford pick up, I used some auto body panel epoxy, to glue a thin, dense, pad of rubber to the frame. Many years later, I'm still very happy I did that, no issues to report there. Maybe it could be benefit you too?
  15. CadMad
    CadMad
    Looking and learning. Will be soon on my agenda to sort out the rear end on my 39.
  16. jivin jer
    jivin jer
    001 (2).JPG With all the time spent under the car looking things over, the C notch definitely looks to be the thing to do. I catch myself when I think thoughts like this because Jesse says that the frame wasn't cut.
    As much as I'd like to notch this frame, I would like to keep things authentic more. Driving around (almost) on the bump stops must have been part of the Jesse Lopez coupe experience.
    This is where I need to be.
    daddio211, Eric H, MUNDSTER and 2 others like this.
  17. BLUDICE
    BLUDICE
    I vote no notch.
    Peanut 1959 likes this.
  18. TheFrenZ
    TheFrenZ
    from Germany
    That looks just right and makes the whole look of the car.Perfect.
    I can't believe Mr. Lopez hasn't c-notched the car back in the day.A car this low definitely needs to be c-notched if want to drive/enjoy it.That's no news.Now or 60+ years ago.Here's a pic of the Sam Barris Mercury at Brizios during resto.You get the idea...
    MUNDSTER likes this.
  19. Torchie
    Torchie
    My unasked for 2 cents Jer.
    If Mr Lopez says it wasn't notched then it wasn't. Something like that is a little harder to forget then say some little detail.
    Notching it would be like putting bags on Juniors Ford. May make it better but then you start to open up that door to all kinds of changes.....
    This could be part of the reason that Mr Lopez ran a dual shock system it the back. Make it stiffer to avoid riding on the axle.
    Looking really great Jer.
    Torchie
  20. jivin jer
    jivin jer
    This thing continues to expand on me. I now realize that I can't just do the rear X member without setting up the dual shocks as well. It's easier and faster to just fab up the brackets myself instead of trying to find something that will work and then wait for them to arrive.. Pics to follow.
  21. jivin jer
    jivin jer
    001 (6).JPG 003 (6).JPG Here's the brackets for the L side coil over shocks. With all the big holes in the inner frame rails, I think the thing to do is "fish plate" the area.
  22. jivin jer
    jivin jer
    The brackets are going to need some refinement as the final fit approach's.
  23. jivin jer
    jivin jer
    001 (3).JPG 002 (2).JPG Here's one of the "plates", and where its going to go.
    justafordguy likes this.
  24. justafordguy
    justafordguy
    from saginaw
    Great stuff, Jerry. Can't wait to see the finished product. You're dedication to details is amazing.
  25. jivin jer
    jivin jer
    Thanks Dave, everything is positioned correctly and tacked together. Then removed and welded up solid out from under the car.
  26. Eric H
    Eric H
    As much as I hate to admit it, my car rests on the bump stops. The ride is actually pretty good but it will get notched this summer.
  27. drdave
    drdave
    I will admit mine is pretty close as well....less than an inch. :) And like you, the ride isn't the worst, but a small notch is somewhere in the future. Looking good Jerry!
  28. jivin jer
    jivin jer
    Here we are all welded up and corrosion protected.
  29. jivin jer
    jivin jer
    OK, almost there. I would like to install the gas tank and get this thing ****oned up, but I gotta do those inboard shocks first.
  30. jivin jer
    jivin jer
    Just about done (what a struggle). Chris (the trimmer) told me to come and see him this week to see if that '57 Chev. was done. I'll see him tomorrow.
      225 KB
