Event Coverage What are YOU doing to get ready for the 2015 Meltdown Drags?
Discussion in 'The Hokey Ass Message Board' started by Okiedoker, Sep 30, 2014.
  1. tricky steve
    tricky steve
    from fenton,mo.
    ha-ha!! i've seen it all (so far)
    yeah, there's your >> T-shirt.
    140 horse 355 chevy,and a 988 H.P. 4 cylinder ford..
    not gonna judge anyone, just thought it would be fun,and well... fun.
  2. Dog_Patch
    Dog_Patch
    Why do all the cool people live so far away? :(
  3. enloe
    enloe
    from east , tn.
  4. Saxxon
    Saxxon
    Beer ?? !!
    Might be worth the 20 hr (ish) drive
    How about bring "real" beer to Meltdown and you guys tell me my engine made the most HP (Not judging)
  5. Pretty sure someone will make the most HP and someone will make the most HS.
    Tickety Boo likes this.
  6. wrenchbender
    wrenchbender
    Sounds fun Steve when we doin this I'm not that far and Ill have two cars a blown sbc in the Willys and a blown injected flathead caddy in the digger the caddy probly make more horse than the Chevy though damn sure make more than that ford Scott's dreaming about lmao
    Okiedoker and saltflats like this.
  7. tricky steve
    tricky steve
    from fenton,mo.
    it's INSANE how much you can learn, ..oil leaks, water leaks, fuel curve,carb spacers, ignition timing.. etc..without hauling to the track,waiting in line.then an hour + in between runs,(if you're on a mission).. >>.. then you know what you need.timing/jetting/spacers/pulleys, etc.. confidence when you pull the trigger (unless you're me.....another story,,,..... yeah, i'm my own worst night mare, I never listen to me..... ) do what i say not what i do.........(duh) you know where you need to be on your tune up...i can run an easy 5 seasons worth of drag races in my room, in a day.. and i don't have to wait in line, then....>>>ooohh i short shifted,wasn't a good burn out... blah,blah,blah.. just data.... but .....and then some body with 577 H.P. corvette runs a 12.80 (!/?) wtf ??? then somebody with 270 h.p.willy's runs 12.00... wtf?? not about the number,it's about optimizing your combination,and having FUN ! yeah it's confusing.(all about torque)
    doesn't matter, no judging here, just fun.,and learning. and giving each other **** about it: )
    i can't tell you what the thing will do in the car, but i can tell you about power.and try my best to make it fun. ..seriously.
    we have the latest, superflow dyno facility,and i an't afraid to use it !!
    Tudor, Dog_Patch and powrshftr like this.
  8. tricky steve
    tricky steve
    from fenton,mo.
    sorry racer-x.
    no ch***is dyno. just a state of the art 902+ superflow engine dyno. sorry, >>my apologies. they (ch***is dyno)have their place,for sure,and can be a life saver in certain situations... and if i was a kazillionaire... i would have both .but engine dyno is my bread and ****er,/ learning tool. while the ch***is dyno has certainly got it's place, for different combinations... and different situations..>>.. for sure.. another story.. but i don't got no stinkin' ch***is dyno.. just pile your junk in your truck bring it !, yeah, 10 pounds of tire pressure = 55 H.P. ,, there's another story.... but as far as things go, they(ch***is dyno) are very useful.
    and i regret not listening to the data.
    doh!! ($$$$$$)
    powrshftr likes this.
  9. tricky steve
    tricky steve
    from fenton,mo.
    bring that ****., let's getter' done !!!
    you set up the time,and we'll make it happen !!
  10. Okiedoker
    Okiedoker
    from Wisconsin
    Tricky Steve-
    Thanks for sending me a copy of Scott's dyno results....what do you guys think?
  11. powrshftr
    powrshftr
    The torque curve won't be quite that flat,but it will be enough to "Rope-a-Dope the Okie Doke"....;)
    Scott
    30dodgeboy likes this.
  12. powrshftr
    powrshftr
    And Jeff just doesn't have enough "Bore and Stroke" to be the "Antidote" to the "Rope-a-Dope".......NOPE.
    Scott
  13. powrshftr
    powrshftr
    So Jeff:
    Just GIVE UP hope!;)
  14. powrshftr
    powrshftr
    And go home and MOPE.
  15. powrshftr
    powrshftr
    Cause if you think you're gonna beat me....You're on DOPE.:D
    Tickety Boo, bigslim55 and 30dodgeboy like this.
  16. bigslim55
    bigslim55
    Well looks like 128 more days to get cars ready if my maths correct...!
    Winters breaking & the B/S & taunting is starting to fly...! This should be fun to see the vortex get ramped up too...!
    Jimbo...
  17. powrshftr
    powrshftr
    Tricky Steve:
    If we were a few miles closer I would be all OVER your generous offer....My little heap can use all the help it can get!:) lol!
    Did you seriously find 60hp with tire pressure....?Whaaa..?
    Scott
  18. 62Furious
    62Furious
    Steve the dino test would be great for the new motor, But there are just a few miles be tween us and the weekends are all I have to get things done around the house for Mama and the garage for the car.
  19. tricky steve
    tricky steve
    from fenton,mo.
    HA=HA-HA-HA!! THIS IS JUST GETTING BETTER !!!!
  20. rawcjw19
    rawcjw19
    Steve I would bring mine down, but I am afraid it may not even run. I would rather save the humiliation for the privacy of my garage, then just ask a bunch more stupid questions on here. Plus If I don't know the actual numbers I can lie about it to my buddies :) It's cool that you are offering though!!!
  21. tricky steve
    tricky steve
    from fenton,mo.
    Yep, ch***is dyno's are inaccurate as far as actual,precise torque readings (except the ones that bolt to axle flanges) even they are prone to variables, IE; gearbox temp,drive line angle, gear set up,then throw a torque converter in there,and that's a whole other story.... .but are a very very helpful tuning tool>sometimes.no way around it,like if your engine is already in the car, or if you have electronic fuel injection, or a bunch of systems built in the car. it's just too much work to transfer all that stuff to an engine dyno. . (computer, wiring harness,fuel system, etc..)
    on a ch***is dyno ,you can tighten the straps, change air pressures, rear axle angle ,transmission oil temp changes output too. main thing on those, is the tuning capabilities,and comparative testing. wow ,they are awesome for that.. for sure !!
    There are lots of variables on a ch***is dyno, . but ,again, very useful tuning tool. as long as you don't move the car, or change your tie down procedure. i use one of those things a bunch at another shop. Really learn a bunch there too .! You need to make a base line test, before you make changes, to be accurate as possible. but most of the stuff we do here is old school, mechanical fuel injection, super chargers. turbochargers, carburetors, dry sump, alky/gas,nitrous. etc.. but don't do much electronic injected tuning stuff. not very convenient to put a racecar on the ch***is dyno, if it's gonna blow the tires off anyway. or a circle track car, ..they have some whacky rear suspension with rear steer in it !! plus as an engine builder, it's much easier to make cam timing changes, look for oil leaks,adjust valves,re-torque heads, etc.. before it's in the car. and i great repeatability.
    **yes, really found 60 H.P.(!) with tire pressure.(14X32X15W slicks)> also changed by changing tie down strap tension,and position of tires on roller.. or pinion angle (!)
    hope that helps !!!
  22. tricky steve
    tricky steve
    from fenton,mo.
    don't even sweat it.. you won't be embarr***ed, I promise. and we don't have to tell anyone the numbers.. just try and make it ready to go !!
  23. tricky steve
    tricky steve
    from fenton,mo.
    yep,would be nice to have both !! for sure !! $$$$$
    Someday maybe .....
  24. Back in the day, lots of guys would "PowerTune" their cars on 400HP, Clayton ch***is dynos. Dad used one in Glendale owned & operated by Rex Carson, with tuning help from Eric Avril. The old PC&J '56 had distributor access through the glove box door, because of the engine set back. They'd get the engine loaded 4th gear, and lug it at the peak torque rpm, and he'd advance the timing until it rattled, then back it of just a tick. When he built the 400" small block, he said he knew it was a good one when it pegged the needle (ran off with the dyno), at only 5000 rpm. I'll add a pic of Eric's 409 powered moly orange 56 when I find it.
    Tickety Boo and powrshftr like this.
  25. tricky steve
    tricky steve
    from fenton,mo.
    that is some cool stuff. also ,talk to isky,and smokey yunick(RIP) that was the good stuff. !!
    i think i was born about 50 years too late,and about 4 million dollars short !! ha-ha!
    Tickety Boo, powrshftr and II FUNNY like this.
  26. 1002029.jpg 1002030w.jpg If you close up above the rear wheel well, it says "400HP Dyno Service", and has Rex Carson signage on the door.
    Dog_Patch, Tickety Boo and powrshftr like this.
  27. tricky steve
    tricky steve
    from fenton,mo.
    this is us dumb***es. (correct redneck language, i spell checked it) at work, we are a custom exhaust shop,we do real good work when it ain't rainin' or if the neighbor don't catch us using their' lectric. !cid_00a401c50169$e8e80200$88e8fea9@computer.jpg
    Then we do some carpentry on the side, (i hold stuff.. ) I'm real good at it.
    then in our spare time we do this: >>
    and this
    Dog_Patch, enloe, 9sectruck and 2 others like this.
  28. rawcjw19
    rawcjw19
    Nice Pic Steve. You have more Blowers in your shop than we do in 3 counties. I can't find anyone around here that knows anything about them.
  29. tricky steve
    tricky steve
    from fenton,mo.
    blowers?? that's easy>>>they go round and round,and break stuff.
    bring your junk down here man.;)
    maybe this won't happen !!
    30dodgeboy, Tickety Boo and enloe like this.
  30. tricky steve
    tricky steve
    from fenton,mo.
