Projects Mercury TopChop blues.
Discussion in 'Traditional Customs' started by Kenneth31coupe, Mar 12, 2015.
  1. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Now it´s time to get this build started.The build is a 50 Merc I will chop for a couple that I know.It was supposed to be started at last fall but when taking out the interior and prepping for the chop there showed up some rust issues.We decided not to rush away with the chop but instead take the time to fix the rott before cutting the roof.The rotted areas was located to upper part of the rockers both sides, p***enger front floor and trunk floor.Most likely the carpet got wet and caused the rust. I started with the trunk and Magnus ( the owner) made a wooden buck for hammer form.
    Here´s the patient. A really good looking car
    The wooden buck and the sheet that will be the new floor
    Here you can see how I heat shrinking the radiused corner over the buck
    Made the beads in the pullmax and here I test fitting
  2. Mercman4life
    Mercman4life
  3. Looks good. .....
  4. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    I will be following this because you Swedish guys are just amazing metal fabricators !!! Larry
    CHUCK50DODGE and 60'coupe like this.
  5. plymouth1952
    plymouth1952
  6. terry k
    terry k
    from toledo oh
    Don't chop it !!! What a great looking car as is....
    Surfcityrocker likes this.
  7. jocktherock
    jocktherock
    from Sweden
    Go,go,go Kenneth..... I'm subscribed. It's upon time we get a smoth traditional chopped merc in our area of living! Will Mange&Ullis build it like an Barris or Ayala clone? Nice collection of Kustomstuff you have in background. Let this be a thread full of pictures! CAMERA aaaaaaand action......
    CadMad likes this.
  8. Devin
    Devin
    from Napa, CA
    Nice work! I'm staring down the barrel of a rust nightmare also. It's cool to see how you did this. I will be following this build.
  9. slddnmatt
    slddnmatt
    Nice work on the patch.
  10. TheFrenZ
    TheFrenZ
    from Germany
    Exciting.Great work so far.I look forward to follow this build.Especially the roof chop.Thanks for sharing.
    (Btw,I NEVER :eek: thought I would say something like this but the forward rake works for me on the stock car together with the '49/'50 skirts.I kinda like the look.)
  11. Jalopy Joker
    Jalopy Joker
    good plan, start with a good foundation first.
  12. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Thanks a lot guys.
    Jock it will not be a clone of one but it will be in early 50s style .
    Frenz.The forward rake is just because of the lack of interior. It will sit with a nice taildraggin stance when done.
    Made a new corner piece for the trunk and have the complete trunk welded in , grinded and done P1020204_800x600.JPG P1020215_800x600.JPG
    Jacob Goodin, Okie Pete and Dave Mc like this.
  13. dlandberg
    dlandberg
    from Sweden
    Looking good! So cool to work with a unchopped 2dr mercury here in Sweden not many of those. Sure will look amazing chopped.
  14. TheFrenZ
    TheFrenZ
    from Germany
    Yes,I totally understand the car won't stay like this.I hate forward rake on cars with skirts.That's a no-no-no.But like I said,it looks okay with the '49/'50 skirts which show more of the rear wheel and the swoopy lower contour helps too.But enough of that.I really look forward to see the Mercury progressing.What plans do you guys have for the chop ? Straight or slanted B-pillar ? Extended quarter windows and rear window in stock position I hope.
    One more thing...what size tires is on this Merc ?
  15. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Tire size is 7,00-15.
    The B-pillars will be slanted,rearwindow stays and so does the beltline. Rear quarter windows will most likely be extended to where they look right. The amount of chop is still a question we debate about, you know the guy who´s one of the owners is pretty tall but his girlfriend on the other hand are quite the opposite. I´m a big fan of Jeff Nepples car and I do my best to talk them into a similar chop but we will see.
  16. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Also made new rockers and p***enger floor board.
    Cut out floor and the bad rocker.
    New floorboard
    Rockers and floor installed
    Jacob Goodin, Squablow and dlandberg like this.
  17. TheFrenZ
    TheFrenZ
    from Germany
    Thanks much Kenneth.Plans for the chop sound right.Jeff Nepple's Mercury is really nice.Jerry Quesnel's Mercury is one of my favorites.But lately a straight post chop is growing on me.Think of Sam Barris' and Wally Walch's Mercury's.It's the more understated way to chop a Mercury.No matter what you do,I know the chop will turn out nice.You do great work Kenneth.Thanks much for sharing.Greatly appreciated !
  18. The 39 guy
    The 39 guy
    Nice work on the floor Kenneth! How did you form the oval openings in the rockers?
  19. jocktherock
    jocktherock
    from Sweden
    YES,a very clean & professional sheetmetal work you've done! Love to see talents like this...
  20. Pinstriper40
    Pinstriper40
    Awesome! Way to fix the other stuff first. It'll make chopping the top that much more fun!
  21. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Thanks guys.
    I drilled a hole in each end of the oval with a holesaw and then I cut between the holes with a anglegrinder. The recessed part surrounding the hole I made in the pullmax with stepping dies. P1020209_800x600.JPG P1020210_800x600.JPG
    Now the rust is done and I have braced the body.I used a square bar to brace the rear window opening. I rolled it in the round braker first so it got the same curve as the gl***.By doing that I think it´ll be easier to see how the roof flows along with the window without having the gl*** in and risking it to crack.Also put in a center bar in the windshield opening for reference when the roof coming down.
    Waiting for the doorhinges to get freshend up and then the doors will go back in before cutting the roof.
    P1020223_800x600.JPG P1020224_800x600.JPG P1020230_800x600.JPG P1020226_800x600.JPG P1020228_800x600.JPG
    Jacob Goodin and 1952B3b23 like this.
  22. loveoftiki
    loveoftiki
    from Livonia,Mi
    Considering Jeff's Merc was chopped by Downriver Kustom Legend **** Dean how can you go wrong
  23. The 39 guy
    The 39 guy
    Thank you for the explanation and photos kenneth!
  24. dlandberg
    dlandberg
    from Sweden
    Looks real good!!! looking forward to se the following steps.
  25. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Know the time has come.Over the hollidays the roof came off ,the pillars where cut and roof tacked back on.Rear window is also mocked up. Thanks to Wolf and Rik for good advices. I cut the A-pillars 4″ along the post ( 3″ vertikal amount) and the C-pillar is cut 5″ vertikal. Rear window is now in it´s stock possition and tilted forward to where it flows with the roof.An even radius from the roof continuing in to gl*** and down to the trunk was the goal and I think it came out great.
    Still not sure if the rearwindow will stay where it is or if I shall move it slightly forward.Have to think about it for a while. Quarter windows is extended 3″ on the top bow.
    When I got the roof and window in place I send some photos to Rik to finish them with color and chrome details for a better wiev and it turned out pretty good I think. Not very far from what I have in mind.
  26. loveoftiki
    loveoftiki
    from Livonia,Mi
    Wow....that looks amazing
  27. Devin
    Devin
    from Napa, CA
    Wow, that looks fantastic. I love it
  28. TheFrenZ
    TheFrenZ
    from Germany
    That's perfect.Very nice work Kenneth.Rik did a nice job too.This is how a chopped Mercury Coupe has to look.Thanks much for sharing.Can't wait to see more !
  29. rottenleonard
    rottenleonard
    Man that looks sweet!
  30. SicSpeed
    SicSpeed
    from Idaho
    The Swedster
    Looks good
