Projects 51 Studebaker business coupe to South East Gasser rules.
Discussion in 'The Hokey Ass Message Board' started by Quain Stott, Feb 21, 2015.
  1. Quain Stott
    Quain Stott
    Jeff one detail make sure your mounting point for the top bar is about 1" in front of the centerline of the wheel. If not it will bend the aluminum plate up right in front of the wheel, if you get it to far forward it will bend the plate down right in front of the wheel. I wish I could draw on a pic on here this would make more since. Call me if you need too.
  2. Dog_Patch
    Dog_Patch
    Great info on the bars! What is the wheel exactly? Should I make a midnight run to the grocery store and cut a couple of wheels of the shopping cart?
  3. enloe
    enloe
    from east , tn.
    Quain,
    I believe it was on one of the other Southeast G***er style build threads that you said there were about 8 build threads going on here for race cars now.
    Do you have the links for those?
    If so could you post them on here?
    I know of about 4 or 5 I think.
    Thanks
  4. El Hueso
    El Hueso
  5. Quain Stott
    Quain Stott
    Tony I'm struggling to find the right wheels. They need to be a max diameter of 3 1/2". 3 " to 3 1/4" is best for the old school look. They need to be small or real big. Anything bigger than 3 1/2" starts to get the modern look even if it's made right. I bought a box of used wheels about a year ago but had to turn them down to the right size, I'm now out of them. Don't use colored wheels that would ruin any effort at making them look old school. Remember the wrong style wheelie bar will kill the looks of an old school g***er about as bad as a set of weld wheels.
  6. Dog_Patch
    Dog_Patch
  7. Quain Stott
    Quain Stott
    It don't say if they have bearings or not, but might get by with out them. Just by looking at the pic they look OK. They look rounded off instead of flat like an old caster. Here's a couple of pic's, the first is an old caster on my engine stand, the second is a 3 1/2 wheel that I turned down to 3 1/4 to give it that flat look. But nobody say's that all casters were flat back then so they will be fine. studebaker 010.JPG studebaker 009.JPG
    AHotRod likes this.
  8. sch-1
    sch-1
    If any of you have a buddy in the elevator business check out the rollers they use for escalator steps or ctw. guide rollers. They have ball bearing and most are black. Many of them are close to 3-3.5" diameter.
    loudbang and Quain Stott like this.
  9. Quain Stott
    Quain Stott
    Enloe here's the SouthEast G***er builds that I know of right now. the first one (border Bandits) is 5 cars in one thread. there are 3 or 4 others on here but they are done finished.
    http://www.jalopyjournal.com/forum/...builds-to-the-southeast-g***ers-rules.950342/
    http://www.jalopyjournal.com/forum/threads/dodge-this-1939-dodge-southeast-g***er-build.938352/
    http://www.jalopyjournal.com/forum/threads/63-falcon-g***er-south-east-g***ers.965872/
    II FUNNY likes this.
  10. enloe
    enloe
    from east , tn.
    cool I was already subscribed to these builds. I was hoping there was some more.
  11. Terrible Tom
    Terrible Tom
    Great thread and nice work. I have a '50 business coupe that I hope to build one day. Mostly complete, but I could use some front fenders as rust has gotten to mine.
      346.3 KB
    Quain Stott likes this.
  12. fast30coupe
    fast30coupe
    from Illinois
    Quain
    Can you post a few more pictures of those wheelie bars. I like your design and the resemblance to old leaf spring wheelie bars. I was planning on making the rigid wheelie bars that come down from the rear of the frame but don't like the idea of not being able to take then off for loading on a trailer or flat bed.
  13. Quain Stott
    Quain Stott
    Tom I'm not sure if david owns the molds for the front fenders or if the guy that made them owns it. I will try and remember to ask, if you don't hear back from me give me a reminder.
  14. Quain Stott
    Quain Stott
    I had the frame mounted bars on my willys when i first built it and there was a problem with unloading the suspension so I changed to the ones like I making for this build. My car is only 101" wheelbase so I decided to try them again on the Pale Rider 55 that I built a few years ago since it was 115" wheelbase same problem so we had to change it.
    We have these mounted on the car now so I'll post some pics of the finished bars for you in just a day or two when I get a chance.
  15. Quain Stott
    Quain Stott
    fast30coupe, Here's some pics with them mounted on the car. be sure to keep the top bar mounting point about 1" ahead of the wheel center line or the aluminum plate will bend. studebaker 010.JPG studebaker 011.JPG
    enloe likes this.
  16. fast30coupe
    fast30coupe
    from Illinois
    Thanks Quain I'll be building a set soon
  17. k5hart
    k5hart
    Dog_Patch and Quain Stott like this.
  18. Quain Stott
    Quain Stott
    A plastic master looks bad out of place on any old school g***er so I always make my signature hand hammered master cylinder cover to hid them. Some don't believe they are hammered out so I'm going to do step by step pics. I start with .040 3003 aluminum unless it has to have a bunch of shape then I use .050. this small shape is going to be .040. Sorry about the pic being dark I didn't know it until I downloaded them, studebaker 001.JPG to late to take any more.
    AHotRod likes this.
  19. Quain Stott
    Quain Stott
    Then a pattern of the size I need, then mark it on the aluminum. studebaker 002.JPG studebaker 003.JPG
    AHotRod likes this.
  20. Quain Stott
    Quain Stott
    Then start hammering. I use a shot bad underneath, if you don't have a shot bag a pile of sand will work just fine. I don't anneal the aluminum like some do unless it has to have a lot of working because it won't hold up good in the future. studebaker 004.JPG studebaker 005.JPG studebaker 006.JPG studebaker 007.JPG studebaker 008.JPG
    AHotRod likes this.
  21. Quain Stott
    Quain Stott
    The next tools I will use are home made dollies. You old timers might recognize the one as and old shoe maker's shoe repair stand. It works good for a lot of things I do around here studebaker 011.JPG studebaker 003.JPG .
    AHotRod likes this.
  22. Quain Stott
    Quain Stott
    The other tool is and old sheet metal *******, can't use a hammer any more because I'm trying to get rid of the hammer marks. studebaker 012.JPG
    AHotRod likes this.
  23. Quain Stott
    Quain Stott
    ******* and dolly and a little time in the English wheel, the wheel will only do the very top. (this can be done with a dolly but the wheel is a little faster). Starting to look like something now. studebaker 010.JPG
    AHotRod likes this.
  24. Quain Stott
    Quain Stott
    now for a mark on the top side so I can start getting the shape right. studebaker 014.JPG
    AHotRod likes this.
  25. Quain Stott
    Quain Stott
    Believe it or not it don't take long to get to this point but now the finishing takes a while. Just a lot of gentle taps with the *******. studebaker 015.JPG studebaker 017.JPG
    AHotRod likes this.
  26. Quain Stott
    Quain Stott
    Getting close but still a little adjusting and still have to roll the sides up flat. I'll use the Little round dolly pictured earlier and work from the back side to do this. studebaker 018.JPG studebaker 019.JPG
    AHotRod likes this.
  27. Quain Stott
    Quain Stott
    AHotRod likes this.
  28. Quain Stott
    Quain Stott
    The sides trimmed and checked for fit in the car. Still needs a few little touch ups
  29. II FUNNY
    II FUNNY
    Hey Quain, what master cylinder do you use? What is your gas pedal ratio? From the pics of your Willys I have...it looks like 1 1/2-1
  30. Quain Stott
    Quain Stott
    My willys is screwed up don't go by it. I had injectors with a crazy ratio linkage when I first built it so I made the petal work with it instead of fixing the injectors. Now I have to have a screwed up mess on anything I put on it. Anyway 1 to 1 is what you want. Most carburetors take 2 1/2" to wide open. 2 1/2" is about the right pedal movement. If your injector have more or less travel fix them so if you ever put carbs on it things will be right. Another thing I do is I now always use a carb to set the petal up and it usual works out close for any injectors.
