63 comet lower it?
Discussion in 'The Hokey Ass Message Board' started by soylent, Mar 24, 2009.
  1. soylent
    soylent
    from FL
    Should I drop my 63 s22 convertible? I was planning on it. New springs up front and 2 or 3 inch blocks in the back? Anyone have any experience in this area? Any and all comments appreciated.
  2. Special Ed
    Special Ed
    Sweet ride! Just drop it, and drive the heck out of it!
    porknbeaner likes this.
  3. That's going to look awesome lowered!
  4. glendale
    glendale
    look into the shelby drop. you redrill the hole that locate the upper a arm. cheap and it improves handling.
  5. Last edited: Mar 25, 2009
  6. Dreddybear
    Dreddybear
    On mine I cut a coil and put three inch blocks in the rear. Looked great. Drove great but had a little too much camber, glendales suggestion I believe fixes that.
  7. soylent
    soylent
    from FL
    Did you do the shelby drop? I think I will do the 3 inch blocks and cut the springs this weekend. Anything else I should know?
    Thanks again for everyones advice, and help!
  8. akreone
    akreone
    from SLC 801
    I lowered my '62 2", the I bought drop springs from jamco and put 2" blocks in the rear. The car handles much better now.
  9. soylent
    soylent
    from FL
    THIS IS THE WAY TO GO!
    NICE! I am going to do the same, what do you think about 3inchs? all around?
  10. i did 3 inches all around, cut coils in the front and removed one leaf in the back combined with blocks and air shocks/on-board compressor.
  11. akreone
    akreone
    from SLC 801
    At the time I still had the stock 13" wheels and with the old rear leaf's, 2" drop was plenty. Since then I have gone up to 14" wheels with taller bias tires and now the 2" drop is kinda weak. While it drives and handles much much better with the new springs and shocks I'd like to go another inch so I'll probably be cutting 1 coil from the front springs. If you go with the Jamco springs just order a 3" drop spring to begin with.
  12. soylent
    soylent
    from FL
    Thanks for all that info! I am going to stick with the stock 13" wheels btw. I will go with with the 3" for sure, and you think3 inch blocks in the rear too???
    Thanks again!
  13. akreone
    akreone
    from SLC 801
    yeah 3" blocks, keep in mind the new front springs will take a little time to settle so the front drop won't be as imediate. I'll try and post up a pic of mine tonight to give you an idea.
  14. akreone
    akreone
    from SLC 801
    LaGrasta...your falcon is probably my all time favorite. I refer to your pics often, lot's of great details and execution.
  15. thank you, I appreciate it.
  16. akreone
    akreone
    from SLC 801
    Here's my '62 with the 2" drop and the stock 13" wheels.
    bubbletopbuick likes this.
  17. soylent
    soylent
    from FL
    That 62 is bad***, heres a pic of my 61 I sold. So you think 3 inch will be alright all around?
  18. akreone
    akreone
    from SLC 801
    This is where I think you'd be sitting with a 3" drop.
  19. soylent
    soylent
    from FL
    HAHAHA! That kicks ***. YDM! I am heading online now to order. Thanks for posting that picture btw.
  20. bubbletopbuick
    bubbletopbuick
    from Indy
    Ok nice. I just found this thread. I ordered 2" drop springs for my 60 comet and thought I'd see if anyone had done the same on here. I see now what shes going to look like.
    What do you guys think about side pipes for mine since its a 4 door? I went ahead and ordered new headers to replace the medieval looking cast iron exhaust header, and also to get a little more HP from this 144. So I'd like to do duals with a couple gl*** packs.
    Your thoughts?
  21. slammed
    slammed
    ^^^PM gimpyshotrods for a bunch of info for improving the drivability of those early I6 of yours.
  22. gimpyshotrods
    gimpyshotrods
    Never heard of him.o_O
    Seriously, do the Shelby drop, and put a 1" anti-swaybar on it.
    Shorty bumpstops help too.
    Your 144 can haul ***, with a few mods. No on the dual exhaust.
  23. bubbletopbuick
    bubbletopbuick
    from Indy
    Akreone, did you need to go to a different type of shock with those springs? I am using 2" drop springs and am trying to figure out if I need different type of shocks.
  24. gimpyshotrods
    gimpyshotrods
  25. bubbletopbuick
    bubbletopbuick
    from Indy
    Cool. Thanks. I put the old ones back in. If they blow out then ill go from there.
  26. gimpyshotrods
    gimpyshotrods
    You should hit the bump stops before the shocks bottom out.
  27. RetroSpeed
    RetroSpeed
    I like the stance of these two Comet convertibles.
  28. RetroSpeed
    RetroSpeed
    My '63 Ranchero project has two cut coils coupled with the Shelby drop and 3" blocks in the rear.
    Wheels are rare 13 inch 5 lug Cragars on Coker 5.20 13 inch tires.
    juan motime likes this.
  29. bubbletopbuick
    bubbletopbuick
    from Indy
    Ok springs are in as well as the old shocks. It is definitely lower by about 1"-1.5". I take it they should eventually settle lower?
    I hope they do because with these 13" wheels I am starting to think I should have went with a 3" drop.
    Havent touched the rear yet.
  30. gimpyshotrods
    gimpyshotrods
    If the springs are new, they will settle. Once they settle, you can cut coils to get the final desired height, suspension travel, and bump stops permitting.
