Technical What are you cleaning your engine with?
Discussion in 'The Hokey Ass Message Board' started by leroux, Mar 16, 2015.
  1. leroux
    leroux
    from SoCAl
    I have cast aluminum parts as do most of you all on your cars. What is everyone using to clean them but not take the "old" off of them. ImageUploadedByH.A.M.B.1426528452.311367.jpg
  2. gnichols
    gnichols
    from Tampa, FL
    I like motorcycle washes, like S-100 and HDs cleaner. Gary
  3. 55Caddy62
    55Caddy62
    Pine-Sol or Simple Green
  4. stimpy
    stimpy
    good old hot water from a steam cleaner , will not mess up aluminum . and on semis we had alot of polished stuff we didn't want to turn white . a little dawn and I mean little Dawn dish soap in the soap dispenser will take the oil film off without bleaching the aluminum . and when I mean a little like 1 table s**** per gallon of dilute otherwise you have a foam fight
  5. HOTRODPRIMER
    HOTRODPRIMER
    Soap and water. HRP
  6. jseery
    jseery
    from Wichita KS
    Tide was always recommended by a lot of engine builders.
  7. 1bigrat
    1bigrat
    Simple Green makes an aircraft cleaner that will not etch aluminum.
