Features Falcons done right?
Discussion in 'The Hokey Ass Message Board' started by guiseart, Nov 20, 2005.
  1. Flootiebuell
    Flootiebuell
    1963 Falcon 2 door with 56k original miles on it.....building a "Clone" road racer, so far this is the work that has been done.
    Maverick 8" rear end, CSRP Granada disc brakes, Open Tracker-standard upper/lower control arms, roller bearing spring perches, roller idler arm, 1" sway bar, 1965 Falcon centerlink, relocated upper control arm (Shelby drop), rolling on 90's Crown Vic steel wheels, with Falken 205/50R/15s.
    Interior has new carpet, and two BMW M3 buckets without head rests, closest thing I could find that looked kinda like old style race seats.. The original door panels, dash and interior paint are perfect, and NO RUST ANYWHERE. All trim in place and good condition....trunk still has original mat in super great condition. Paint is Plastidip light blue, and the bumpers, wheels, and trim are Plastidip Metallic Silver. Still has the original 170ci 6 cylinder, and auto trans.
    This little Falcon handles great with all the suspension upgrades. Next up a nice little 302 and T-5.
  2. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Nail:
    The car had these mounts for two years with two different V-8's: the 302 it came with and the 347 that replaced the 302.
    After somebody gave me the earlier cast lower mounts, I bought the remaining early style pieces from a Mustang vendor and installed them.
    The placement of the engine didn't change at all- I just jacked the engine up an inch and bolted all the earlier stuff in along with the "under engine" brace.
    I think it took about 45 minutes with a smoke break between sides.
  3. Nailhead A-V8
    Nailhead A-V8
    wow I really dig your undersides! those pans are nice the brace is skookum and I dig that you incorporated the stock stop switch into your fluid block
  4. Nailhead A-V8
    Nailhead A-V8
    - Thanks again Burnt I will go with the mustang much easier to find yea i'm stoked!
    Nice work flootie and Auto
  5. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    "skookum" must be a Canadian thing...
    Because I can't leave well enough alone, I quit using the pressure switch and converted to a 65-up Ford pedal mounted mechanical switch:
  6. Bigcheese327
    Bigcheese327
    I had the same thought a while back. I researched it out, but the MoPar little caps and the Falcon little caps are different sizes and won't interchange. I think I detailed it out on a thread on TFFN at the time.
    I've yet to find a good solution for putting the bottle caps on a five-lug wheel or any wheel that will clear disc brakes, hence the '62 Galaxie dog dishes on my '62 Falcon with Maverick wheels.
    If you figure it out, be sure to let us know!
  7. Nailhead A-V8
    Nailhead A-V8
    ha ha lol ya pacific northwest jargon (eh) it means: tough, durable....
    Big I did the same thing with a '65 2 dr. I had a set of the galaxy caps and mav 14"rims which are essentially the same style from '67-'78 with early ones having the small hub........I also had a '65 4 dr. that came with 14" 4 lug rims it also came with a set of 13" both of them fit the stock '65 caps I thought the 14" set were probably Mustang rims if someone can compare the 60-63 caps to the 64-5 caps and IF they are the same diameter then I can almost guarantee the caps will fit the early '60's (pre-67) 14" rims they will fit the falcon caps but have the small hub register so it seems to me the easy way would be to hog out the centers....can anyone check the cap diameter? what about the drum brake guys? anyone running stock caps on a V8 drum hub 14" wheel?
  8. Nailhead A-V8
    Nailhead A-V8
    - Big cheese the falcon caps are 9 1/8th diameter I believe V8 falcons had a 5 lug rim and used the same hubcaps they should be fairly common too but that is supposition can anyone verify this?
    if so the centers could be bored out to the disc register for 14" rims
    - alternately for "15 rims the chrysler cap mount is 8 3/4 and provide a nice flat surface to either weld a few ballbearings on or you could add a little weld on to bring the tabs out to 9 1/8th
  9. Nailhead A-V8
    Nailhead A-V8
    so nobody on this site ever had a 63 v8 falcon/comet/fairlane?
  10. Nailhead A-V8
    Nailhead A-V8
    although I appreciate the advice to check out these Falcon threads and looking at 100's of cool falcons is entertaining i'm finding it exhausting to glean any technical info from all these posts and yes of course i've searched........maybe i'm not using the right keywords........I started a thread and 5 people posted that I should post them on this thread but I think it has petered out.......
  11. gimpyshotrods
    gimpyshotrods
    We're still going. I am about to post some more pictures of my ongoing Falcon evolution.
    More gears, more power, not more cylinders, or more lugs.
  12. Mike51Merc
    Mike51Merc
    Have you tried The Ford Falcon News (www.tffn.net)?
  13. Phillips
    Phillips
    Not sure if this is what you are asking, but I did have a v8 63 Fairlane - same center caps as Galaxie, and Falcon caps were too small. And I know it had the original wheels/caps as it was bought new by my grandfather.
  14. Nailhead A-V8
    Nailhead A-V8
    -Ok Gimpy we will keep it alive
    - Thanks Mike will check it out
    - Thanks Phillips theres the answer.........ok back to the drawing board
  15. The Law
    The Law
    from N. AZ
    It's probably not everyone's cup of tea but here is my 63 Sprint. I just finished up the exhaust, and ended up having to dump it in front of the tires. The rear end is to low and the 4 link is in the way so I could not run it out the back. Please disregard the header leak... its on the list...
  16. Nailhead A-V8
    Nailhead A-V8
    sounds rad i've always liked the look and simplicity of the "track" style exhaust
  17. The Law
    The Law
    from N. AZ
    Thank you! I'm just wondering how loud its going to be in my ear with the window down.
  18. Nailhead A-V8
    Nailhead A-V8
    Does anyone know of a radiator that fits in the tiny '60-'63 rad support opening? preferably 3 core I'd love a custom made one but couldnt afford it I was thinking V8 mustang II does anyone remember what year they changed sides for the waterpump exit on the small block?
  19. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    64-66 Mustang radiator has p*** inlet/outlet and same mounting flange 60-65 Falcon.
    Most all 351W have driver's side w/pump outlet.
    First year for 302/5.0 Windsor based SBF driver's side w/ pump outlet is 83, I think.
    But I'm heavily medicated today so I could be wrong.
  20. Nailhead A-V8
    Nailhead A-V8
    Thanks Burnt isnt that Mustang rad a tad too tall for the early rad support? or am I thinking of the '66-'69 Falcon rad? one I know is too tall
  21. Mike51Merc
    Mike51Merc
    I have both '63 Falcon and '65 Mustang 3 core 18" radiators and they are identical and they keep my 302 cool with just a mechanical 5 blade fan.
    I believe Ford changed the outlet in '69-'70.
  22. Nailhead A-V8
    Nailhead A-V8
    Thanks Mike I put a mid 70's 250 Maverick 6 cyl rad in a '64 Falcon once and I believe i had to significantly alter the rad support and I also stuck a 67 Falcon rad (maybe its closer to the fairlane? in size than the mustang) in a '68 Mustang (out of necessity) and it was too tall....I think you are right those two options are out .....is your '63 Falcon rad from a V8? I thought you had to at least notch the support to use the 64.5-66 Mustang rad? but I have C.R.S. (can't remember sh...)
  23. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    I have an aluminum CHICOM 3 core with driver's side outlet radiator for 64-66 Mustang and the hood closes fine.
    Somebody gave me a Mr Gasket Thermocap with a temp gauge in it and the added thickness of the cap wouldn't let the hood close. Regular cap worked fine.
    I believe 67 up radiators are larger.
  24. Mike51Merc
    Mike51Merc
    Nailhead,
    Mine are both V8 radiators.
  25. The Law
    The Law
    from N. AZ
    I tried my had at squirting some paint on my Falcon. It's a single stage Wimbledon White. I've never done this so its been a steep learning curve. I don't have a bunch of bucks in equipment for paint. Honestly I'm really relying on the meticulous prep work to make this come together nicely. I have shot out of a few different budget guns and oddly enough I've had the best luck with my 20 dollar Harbor freight purple gun. Yes I'm in my garage, yes there is probably junk in the paint. But I'm fairly please how its coming out.
    loudbang and Muttley like this.
  26. The Law
    The Law
    from N. AZ
    IMAG0423.jpg IMAG0424.jpg I finished spraying the car today. It's obvious that I am going to spend some time color sanding and buffing. I'm still pleased with the outcome as I expected the cut and buff would be necessary to really make it look nice. Some areas have a lot of overspray as well. If I were to do It again, I'd buy a better gun. All in, it has cost me about $250 to paint the car. Pictures after color sanding... May be a while. Thanks for looking.
  27. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    When it comes to automobiles, there ain't much that I haven't done- with one exception: body work and paint.
    (Although I did once spray bomb my entire 1957 VW Type I with gray primer back in high school, but that don't really count.)
    Good on you for having the balls to boldly go where most of us would never attempt to go in our garages.
    Not bad for a stick wiggling meat servo.
    Carry on dude.....
  28. The Law
    The Law
    from N. AZ
    Thanks. I just got tired of not having the thing painted and the prices people want for a paint job are just insane if you ask me, and outta my reach. So I figured I would give it a shot. It's a lot of work but hey, now it's one color and hopefully it'll be presentable!
    coneman likes this.
  29. need louvers ?
    need louvers ?
    Looks very nice The Law!
  30. The Law
    The Law
    from N. AZ
    IMAG0427.jpg ok now I'm excited. This looks way better than I was expecting. Also experienced a little set back. I put the paint on a little light on the bottom of the drivers door and sanded through it with 1000 grit. I should be able to blend it? Does anyone have any advice on blending a spot in? Thanks for the encouragement guys.
    droppedstepside and Thor1 like this.
