Projects Re: How to un-chop a `32 Ford
Discussion in 'Traditional Hot Rods' started by sailingadventure, Feb 13, 2014.
  1. merc53pu
    merc53pu
    I wish I had of known about your roof raising project earlier.
    Over the last 20 years I have chopped several 32 & 34 fords. I believe I have all of the pieces we cut out saved up in a 5 gallon bucket somewhere.
    Looks like you've done an excellent job.
  2. kidcampbell71
    kidcampbell71
    Nothing wrong with "look what I can do" posts.....what I need is some of those "where the hell am I gonna' make some money" posts....so I can give you something to "look what I can do" for me, please. :) You guys are amazing. Real deal craftsmen......and to be honest with you.....nothing is more frustrating then watching someone like you "work".....and then try to find the same kind of capable "craftsmen" locally. Having said that, there is always a premium in discovering someone with your talents, deservedly so. BUT AGAIN, trying to convince some of the *****s one typically finds in these endeavors, that no matter what THEY think....they will never come close to your level of talents, and my level of satisfaction. Hence the appearance of a sometimes bald spot above each of my ears, and black and blue between my eyebrows....with me ripping my hair out....and banging my head upon the nearest solid wall.
  3. Hill_County-rodshop
    Hill_County-rodshop
    Nice work, but I would've left it chopped! Guess the ole sayin' is right....opinions are like a-holes everybody has one.
  4. Buddy Palumbo
    Buddy Palumbo
    That's some great work there - keep it up !
  5. sailingadventure
    sailingadventure
    OK, here are a few pictures of the exhaust system. Steve bought some "U" bends to make the turns in the pipe and cut them to fit, kind of like making a set of headers. After tacking the pipes together they were TIG welded. The pipes have flanges to make possible to remove them when needed. The flanges were not welded on the end of the pipes, but a couple of inches back and the pipes slipped into the mufflers for a more air tight seal. Heat shields were made by welding a couple of bolts on the pipe where needed. A piece of the pipe was cut out and spaced with lock nuts.
    The upholstery of the seats is on hold while practice continues with the new sewing machine.
    Meanwhile, the fenders are being prepped for paint.
    kidcampbell71 and LOU WELLS like this.
  6. Pewsplace
    Pewsplace
    Nice sedan, basic traditional hot rod with quality work. Thanks!
  7. Malcolm
    Malcolm
    from Nebraska
    This car is turning out great... Very nice work, guys!
    Malcolm
  8. ken1939
    ken1939
    Outstanding work. I do appreciate you fixing this chop and letting us in on it.
  9. rockable
    rockable
    In a few more years, you guys might actually get good at this. ;)
  10. sailingadventure
    sailingadventure
    002 (800x600).jpg 001 (800x600).jpg 002 (800x600).jpg 003 (800x600).jpg 027 (800x600).jpg 030 (800x600).jpg View attachment 2773431 038 (800x600).jpg 032 (800x600).jpg Well, it`s been some time since I`ve updated this thread, but we`ve been busy. Steve is just about finished with the interior and here are some pictures.
    The interior is finally finished and now it`s time to get the fenders ready for paint.
  11. brady1929
    brady1929
  12. pigfluxer
    pigfluxer
    Looks like you guy's figured out that sewing machine,look's great.
  13. sailingadventure
    sailingadventure
    Things sometimes move slowly around here but the car is finally roadworthy and has been driven some to shake out the bugs. Here are a few pictures of the `32 as it is now. We were moving things around the shop this morning so I took a couple of pictures. The videos were taken in January. Steve`s working in the fenders and hopes to have the car completed soon. Mooving Day 011 - Copy.JPG
    kidcampbell71 likes this.
  14. rusty rocket
    rusty rocket
    Very very nice. I see the gl*** has a blueish/ greenish hue. can you fill me in on what gl*** you have used?
  15. Harps
    Harps
    Great to see it on the road. Love the video and picture updates.
  16. sailingadventure
    sailingadventure
    I think it`s just the way the camera recorded it. It`s automotive flat laminated gl*** that was cut to the patterns Steve made. The gl*** has a green tint.
  17. Loved how you did the top - and a very good thing to think about (having something solid to glue the material too! ) Was wondering if you'd ever thought about an 1/8" piece of other material - like a poly/plastic type stuff? I guess the top material should never leak, so it doesn't matter . . . just pondering out loud!
    Great post!
    B&S
  18. Very, very nice. I'm curious, what was the donor car for the 3 speed overdrive?
  19. sailingadventure
    sailingadventure
    It was a `51 Ford. We used a transmission adapter, but what a pain in the *** it was to make the clutch work with this set-up. Ford disc, chevy pressure plate, and we put in the wrong release bearing the first time. Pulled the transmission, replaced the bearing, still wouldn`t release. Pulled the transmission, saw that the hub on the Ford disc was too long to let the release bearing push the pressure plate down far enough to release. Had to cut the hub down. Re installed everything, still wouldn`t release, ****! Then we played a little with the clutch linkage ratios, made another arm for the cross shaft, still wouldn`t release. Then I decided to put some very thin washers between the pressure plate and flywheel. This would reduce the pressure plate spring pressure a little, but not enough to cause a problem. It also moved the contact point between the release bearing and the pressure plate spring back and gave enough travel to work. SUCCESS! And then we moved on to the next problem. The car would go into low gear once and reverse once, but then it would lock up. What the hell is wrong now? It seems that when the used shifter was taken apart the last time, some dumb-*** (ME) put the spring that pushes the shifter into 2nd gear when shifting from first to second, on the wrong side of the shift arms. Now the shifter worked, but the transmission still locked up when shifting from first to reverse. After another sleepless night, I pulled the shift plate off of the transmission and realized that when I built the transmission, I had re ***embled the low and reverse arm on the wrong side of the slot in the reverse gear. This also engages the part of the overdrive that allows the car to back up. Finally everything works , should have used a 5 speed, but this is a traditional hot rod and we wanted it to be period correct.
    Johnboy34 likes this.
  20. Harms Way
    Harms Way
    Great work !......
  21. banginona40
    banginona40
  22. scotti32
    scotti32
  23. ESGEE
    ESGEE
    from Sweden
    Great thread from first to last. Fresh save...
  24. sailingadventure
    sailingadventure
  25. ididntdoit1960
    ididntdoit1960
    from Western MA
  26. Very nicely done! Thanks for sharing!
  27. falcongeorge
    falcongeorge
    from BC
    That sounds good, like a small-block should! Outstanding. Love all the vintage corvette parts, like the engine mount and nine fins, really nice. I think the chop is right on the money. What a nice car, beautiful work.
    Had to listen again, what sweet music...
  28. falcongeorge
    falcongeorge
    from BC
    Really like the aqua pinstriping...I'm guessing the cam is an 097?
  29. mike bowling
    mike bowling
    From kinda "ratty" looking to an absolutely gorgeous auto- nice job. A+
