Technical Is there a difference between mercury pistons made untill 1948 and those made from 1949 to 1953?
Discussion in 'The Hokey Ass Message Board' started by Tiago Soliman, Mar 18, 2015.
  1. Tiago Soliman
    Tiago Soliman
    from Brazil
    Suppose I had a set of pistons from a 1948 Mercury with a 3.75" crank.
    Can I put them in a 1949 engine with a 4" crank?
    I know the bore is the same, and I know that the Mercury crank had a 3.75 stroke until 1948, gaining the famous 4" stroke crank only in 1949.
    I also know that when you exchange a ford crank (also 3.75") for a Mercury 4" crank you also have to change the pistons, due to the pin location.
    Couldn't find any clues in the existing threads.
    Thanks!
  2. steves29
    steves29
    Look at the Speedway catalogue or VanPelts has a nice parts listing.
  3. alchemy
    alchemy
    Nope, can't enterchange them. The pin to top height is different because of the different stroke.
    Chris likes this.
