Projects 1950 Styleline coupe kustom build thread.
Discussion in 'Traditional Customs' started by Devin, Jan 14, 2015.
  1. Devin
    Devin
    from Napa, CA
    ImageUploadedByH.A.M.B.1426452611.768018.jpg ImageUploadedByH.A.M.B.1426452625.000886.jpg
    I little bit if folding around some square tube to make the channel.
    Marked off where the patch will be. ImageUploadedByH.A.M.B.1426452722.184096.jpg
    And cut it out
  2. Devin
    Devin
    from Napa, CA
    Then made the top couple inches if the bracing that will need to be replaced. ImageUploadedByH.A.M.B.1426452784.934898.jpg ImageUploadedByH.A.M.B.1426452798.550914.jpg
  3. Devin
    Devin
    from Napa, CA
    Holy ****! There's nothing left! ImageUploadedByH.A.M.B.1426452870.451085.jpg
  4. Devin
    Devin
    from Napa, CA
    Tacked the braces in but I need to redo the one on the left as the flange is at an off angle.
  5. 1950heavymetal
    1950heavymetal
    Wow this build has a ton of great work! Thanks for the ideas. Maybe this has been covered and as a novice I ask this question, what thickness steel are you using for all the patch panels?
    Posted from the international space station
  6. Devin
    Devin
    from Napa, CA
    Thanks. I am using 18 gauge cold rolled. I think it's slightly thicker than stock especially due to the rust. When I ground the weld beads down I try to concentrate more on the replacement metal due to that. I'm hoping to sneak into the garage this afternoon and get a little more done.
  7. 1950heavymetal
    1950heavymetal
    Thanks for the info and keep up the fantastic work!
  8. JackdaRabbit
    JackdaRabbit
    from WNC
    Devin, you're doing great work, honing mad skills and I'm picking up some good tips........but dude, couldn't you find a little more solid shoebox Chevy to start with - being in Cali and all? That car seems rotted in all the difficult places.
  9. Devin
    Devin
    from Napa, CA
    Thanks for the compliments, just trying to learn. And yes, I should have p***ed this one by, but I didn't lay any cash out for it. Penny wise and pound foolish I was. Oh well, I'm looking forward to getting better at this stuff and this gives me plenty if opportunity lol.
  10. Bruce A Lyke
    Bruce A Lyke
    As Clark Griswold would have said "it's all part of the experience Audry".
    Good practice for a car down the road with no other options. At least what i told myself on my rusty wagon.
  11. Ratatouille
    Ratatouille
    from France
    We own similar tool![​IMG]
    Good job, bro ;-)
  12. JackdaRabbit
    JackdaRabbit
    from WNC
    No disrespect Devin. It's all admiration for the stiff challenge of a low buck approach and putting more of your own stink into a build. That's where rodding and customizing lives.
  13. Devin
    Devin
    from Napa, CA
  14. Devin
    Devin
    from Napa, CA
    La meme siege aussi!
  15. Devin
    Devin
    from Napa, CA
    Getting killed at work right now. All I've been able to do was get the brace patches and the drip pan tacked in. Most likely all I will get to for a while. Progress is progress I guess. ImageUploadedByH.A.M.B.1427075532.502906.jpg ImageUploadedByH.A.M.B.1427075545.634950.jpg
    ratty_aussie likes this.
  16. seanbelushi
    seanbelushi
    I've been there with mine. You're doing a great job, and I promise that one day, the rust repair will end!
  17. Devin
    Devin
    from Napa, CA
    I hope so! I'm just getting started. I think I'm going to have the body dipped when I'm done just to protect the investment of time and energy.
  18. Devin
    Devin
    from Napa, CA
    Finally got away from work and snuck into the garage for a little it today. I finished welding in the braces and the replacement inner window structure. Welding this was a ***** because the sheet metal was so thin. I blew a lot if holes in it and spent a great deal of time filling them up. I didn't spend much time trying to metal finish because I was worried about further thinning the ironical metal and also because it will be covered by the garnish molding. The body is so much more rigid and solid now. The pics **** due to the light coming in. ImageUploadedByH.A.M.B.1427857814.388619.jpg
  19. Devin
    Devin
    from Napa, CA
    Started to fit the outside patch panel but didn't get too far.
  20. Devin
    Devin
    from Napa, CA
    I'm going at a snail' space but at least I got the panel welded in today. ImageUploadedByH.A.M.B.1428370801.523625.jpg ImageUploadedByH.A.M.B.1428370815.355728.jpg
    Peanut 1959 likes this.
  21. Devin
    Devin
    from Napa, CA
    Got most of the p***enger side catwalk section replaced today. ImageUploadedByH.A.M.B.1428978218.722930.jpg ImageUploadedByH.A.M.B.1428978230.339317.jpg ImageUploadedByH.A.M.B.1428978240.306332.jpg ImageUploadedByH.A.M.B.1428978255.439146.jpg ImageUploadedByH.A.M.B.1428978281.055376.jpg ImageUploadedByH.A.M.B.1428978292.221828.jpg ImageUploadedByH.A.M.B.1428978303.171484.jpg
    Ran out if time before I could finish welding and dressing.
  22. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    That's looking real good man, keep it up.
  23. Slopok
    Slopok
    You must've found the only car in California that came from Illinois, nice job you're doin there though.
  24. Devin
    Devin
    from Napa, CA
    Thanks!
  25. Devin
    Devin
    from Napa, CA
    Lol. I know I must be a glutton for punishment. "If it ain't hard it ain't worth doing" they say. I hope they're right! I'm having fun and learning a lot.
  26. Devin
    Devin
    from Napa, CA
    ImageUploadedByH.A.M.B.1429233163.537909.jpg ImageUploadedByH.A.M.B.1429233177.620908.jpg ImageUploadedByH.A.M.B.1429233186.088788.jpg ImageUploadedByH.A.M.B.1429233201.687625.jpg
    Made up the bell one out of a strip. Ran through the shrinker to get the curve and then formed the contour with an oval post anvil. This one was easier to make than the other one. It still needs some tweaking but I'm happy with the results.
  27. dlandberg
    dlandberg
    from Sweden
    Looking real good! Keep it coming
  28. Ratatouille
    Ratatouille
    from France
    Great metal work! Bravo.
  29. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Bravo !! Devin, I remember taking on projects like that years ago and feeling the same pride and sense of accomplishment that you must feel ! But now at my current shop rate I am looking at 2o grand worth of metal work!!!! lol but I am glad you have the kahunas to save it!!! Again great work keep it up! Larry
  30. Devin
    Devin
    from Napa, CA
