Hot Rods AMC Rambler American 220 l-head firing order
Discussion in 'The Hokey Ass Message Board' started by Dezert_Racer, Mar 21, 2015.
  1. Dezert_Racer
    Dezert_Racer
    i need a picture or diagram for the L head flat 6 so i can get the plug wires right any help? out there
  2. RB35
    RB35
    The only Motors manual I have has no listing for a Rambler, but I imagine 1-6 front to back. Is there a firing order on the manifold or head? What year?
  3. Dezert_Racer
    Dezert_Racer
    it is a 63 i have the order just not where the plug wire location on the cap
  4. z-4wheldrft
    z-4wheldrft
    from s.e.pa.
    this should be correct
  5. Dezert_Racer
    Dezert_Racer
    thank you so much
  6. RichFox
    RichFox
    Every inline six i have ever seen, and that is quite a few, is 1-5-3-6-2-4
  7. ClayMart
    ClayMart
  8. farna
    farna
    The distributor drive gear for the L-head is actually attached to the oil pump. The dizzy shaft has an offset slot in the end so it will only go in one way. That's good because you need to pull the dizzy to change/adjust points. Just note about where the body is turned before pulling. But if the engine has been rebuilt the wires on the dizzy may need to be moved because the timing of the oil pump moved. Lots better than trying to pull oil pump and time it that way!
