Technical 305 making knocking noise
Discussion in 'The Hokey Ass Message Board' started by 56 and 60, Mar 24, 2015.
  1. 56 and 60
    56 and 60
    My 305 engine started making noise while it was in driveway.
  2. Unkl Ian
    Unkl Ian
    And then what ?
  3. indyjps
    indyjps
    Well drive it into the garage and replace the 305 with a tree-fitty.
    Seriously man, can you give more details
  4. 56 and 60
    56 and 60
    My vid clip is too large for site, I am creating a you tube account.
    I can not figure out what the sound is. I think maybe lifters, but want some opinions before I start taking everything apart.
  5. Mr48chev
    You do have the right amount of and did not run out of oil I take it?
    They sell a stethoscope in the tool section of Autozone, O'Reilly's, Sears and probably Harbor freight for about the price of a six pack of decent beer that you can listen to the engine at various spots to try and pinpoint the noise.
    You can pull one plug wire at a time with it running to see if you have a rod knock but need a pair of insulated pliers to do it or get knocked on your **** by the spark. That's not proof positive but a real good indicator that you have a rod bearing gone bad if the knock quits or gets faint when you pull the plug wire on the cylinder with the bad bearing.
    One more thing before you do any thing drastic. if it is an automatic put it in gear and put a load against the trans to see if the knock goes away. A cracked or broken flex plate or loose converter bolts can cause a hell of a knock and got me a free truck with an Olds 350 in it that I put in my 51 Merc back years ago. At an Idle in the driveway the thing knocked so loud that you thought the rods were coming though the side of the block but the knock quit when you put it in gear with your foot on the brake and gave it a bit of gas. Three minutes with a 9/16 wrench and I had an engine that I put probably 80 K on in my Merc including a trip to Texas and Bonneville in 1988. Something to try before you tear it all apart.
    tb33anda3rd and Hnstray like this.
  6. Unkl Ian
    Unkl Ian
    How much oil pressure ?
  7. gimpyshotrods
    gimpyshotrods
    Broken flex plate, or exhaust leak, by the head.
  8. jimcolwell
    jimcolwell
    from Amarillo
    Yes, if it's a rod bearing you'll loose oil pressure. The spark plug idea is good and will work. The flex plate idea is also good.
  9. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    ^^^^^ why I love the Hamb :)
    Unkl Ian likes this.
  10. 56 and 60
    56 and 60
  11. 56 and 60
    56 and 60
    The oil is to the full mark. The oil pressure is at 35lbs. I took off the cover and inspected the flexplate for cracks. I turned the engine to see all sides. I tried a real stethoscope with the end taken off and cound not narrow it down. By ear, sounds like it is under intake, but don't know for sure. I need to by insulated pliers because felt the shock through my arm yesterday before I finished.
  12. yruhot
    yruhot
    454 in the 55 chevy did the same **** while loading it on to trailer. thought the worst. put up on rack and flex plate to crank bolts had loosened up just a hair. Slid trans back removed bolts and reinstalled with some lock***e on threads. All healed. amazing. I was doing the happy dance. noise gone. Yruhot
  13. gimpyshotrods
    gimpyshotrods
    The cracks that make this noise will be on the flexplate in an area that you cannot see. You will need to back the transmission up enough to get a ratchet in in there, and remove it.
    stealthcruiser likes this.
  14. slammed
    slammed
    Sounds like semi auto rifle fire.
  15. 56 and 60
    56 and 60
    The vehicle is a 56 GMC. The engine is a 305 with 416 heads, air gap intake, edelbrock 650 avs carb, stock exhaust manifold, edelbrock 2102 cam, stock rockers, 700r4 ******.
    I bought the engine a couple months ago (they had it advertised as a 350, should have looked at it better before buying). The engine was running good for a few days(over a few weeks) before noise started. I only drove it around the block once before problem. I tried adding 5 gallans of 92 octan3 to tank.
  16. slammed
    slammed
    Did you bolt the flex/converter/trans together yourself? Torque the bolts for the fly wheel?
  17. Holy **** !
    That's freaking noisy :D:eek:
    Sounds like the pistons are swapping holes. Something in that engine wants out in a bad way.
    Sounds like something rubbing, a bearing knock is more like tapping on the block with a hammer sound.
    That fan looks bent,
    that engine went from quite and smooth right to that in the driveway all of a sudden?
  18. BadassBadger
    BadassBadger
    from wisconsin
    I KNOW WHAT IT IS.....most likely
    its a bad camshaft. the late 70's 305's all eat camshafts due to the **** metal they used in them. i had mine in my 79 impala go. when i pulled it out i **** you not the number #1 lobe was nearly round.
    tb33anda3rd likes this.
  19. 56 and 60
    56 and 60
    Will it make a difference if I put it drive or neutral?
  20. 56 and 60
    56 and 60
    U
    hard to use a stethoscope to pinpoint the noise when something is shooting at you.
  21. 56 and 60
    56 and 60
    The fan is a weird on
    I Installed myself. I used new star washers and loc***e. I hooked up the transmission as well
  22. 56 and 60
    56 and 60
    The fan is originally from a 327 engine that was is truck before. it didn't make any noise.
  23. 56 and 60
    56 and 60
    [QUOTEd***Badger, post: 10910592, member: 127999"]I KNOW WHAT IT IS.....most likely
    its a bad camshaft. the late 70's 305's all eat camshafts due to the **** metal they used in them. i had mine in my 79 impala go. when i pulled it out i **** you not the number #1 lobe was nearly round.[/QUOTE]
    I
    I was thinking of pulling intake manifold to check lifters for wear, could be the cam. It is an edelbrock cam, not stock.
  24. 56 and 60
    56 and 60
    I have unistalled the fuel pump and engine ran the same without it. It was a well spent $2.98 (.99 for one gasket and 1.99 for other) to rule that out.
  25. 56 and 60
    56 and 60
    1 minute video. Took over 1 hour to download to you tube.
  26. 56 and 60
    56 and 60
    Screenshot_2015-03-24-22-47-28.png I didn't design it, just painted it pontaic blue metallic and installed it. Mine is old, not this reproduction.
  27. LM14
    LM14
    from Iowa
    Take your fan belt off and run it a little bit. Water pumps (especially with bent fans killing the bearings) and alternators can make hard to find noises. Please replace that fan before you kill yourself.
    When you have that belt off, check your harmonic balancer, they can sometimes work lose.
    Take the valve overs off and get each cylinder up to TDC one at a time and see if you have lash on any cylinders. Lash on a hydraulic cam = a bad adjustment to begin with, a stud pulling out of the head, a bad/broken rocker arm, bent pushrod or valve, or bad cam/lifter.
    SPark
  28. footbrake
    footbrake
    Yes ,pull the valve covers first and see if any rockers are off the pushrods or some aren't moving at all
    hipster likes this.
  29. bobss396
    bobss396
    I agree with taking the belt off and see what it sounds like. That bent fan will eventually kill the water pump bearing. It sounds too irregular to be something serious.
  30. chiro
    chiro
    ^^^What SPark said. Had a 289 that the rocker stud pulled out of the head on that sounded like that. Spark has the best ideas yet. I'm thinking water pump maybe also. Pull the belt and run it, then valve covers.
    Andy
