Projects 63 Falcon Gasser (South East Gassers)
Discussion in 'The Hokey Ass Message Board' started by sonic03bluegt, Mar 3, 2015.
  1. sonic03bluegt
    sonic03bluegt
    from sc
    shop was a wreck! got the front half of the frame painted and the front axle done as well. Used a latemodel ford color that is very similar to gunmetal on the axle and used blp eggshell black on the frame. I started trying to use rattle can on the frame but quickly realized it was going to take forever and would cost a fortune
    pulled the rear end out from under the car so that i could paint evertything seperate as well to give it a cleaner finished look
    els, Butch M, volvobrynk and 3 others like this.
  2. avmechanic
    avmechanic
    Nice Build. The hard work will all pay off soon. Keep at it. Looking forward to seeing it finished.
    Cheers.
    Greg
    els likes this.
  3. sonic03bluegt
    sonic03bluegt
    from sc
    a shot from the back looking forward. Took a couple of hours with a wire brush and cleaned the rear rails up
    got my gauges stuck in and the cage painted. Old tach and stewart warner oil and water gauges
    els, Butch M, volvobrynk and 2 others like this.
  4. sonic03bluegt
    sonic03bluegt
    from sc
    front end put back together and under the car to stay hopefully
    rear end re ***embled and painted. Ready to go back under
  5. sonic03bluegt
    sonic03bluegt
    from sc
    another shot of the rear end. It has 35 spline axles etc. Will prob need braced up a little better if i start making big power but should do just fine for now
    Ready for the rear end to go back under
    els, Butch M, volvobrynk and 4 others like this.
  6. Saxxon
    Saxxon
    Cool build.
    Love the paint silhouette on the floor. In my shop you can track the history of all the builds by the paint signatures left behind. Same for the splash painted pliers... I have a couple of vice grips that have 7 or 8 shades of paint on them. Looks like the 70's puked on them.
    els, volvobrynk and loudbang like this.
  7. sonic03bluegt
    sonic03bluegt
    from sc
    checking ptv clearance before i sent the rotating ***embly off to be balanced. The engine had been ***embled for the last few years and sitting on a stand waiting to go into another project of mine but the falcon got fasttracked so i swapped out pistons for a set of je domes i had and sent it off to be rebalanced
    els, volvobrynk and bigjohndsl like this.
  8. sonic03bluegt
    sonic03bluegt
    from sc
    Last update for the day. Engine is currently still torn down awaiting rotating ***embly to come back from being balanced then i will stick it together and it will be ready to go
  9. sonic03bluegt
    sonic03bluegt
    from sc
    got the line lock on and the brake lines ran the other night. I think they turned out ok.
    Finished painting my pedals as well. took a couple of hours cleaning up the master cylinder as well. It was under a couple of coats of red oxide primer when I got it
  10. sonic03bluegt
    sonic03bluegt
    from sc
    another angle. Im pretty happy with how everything is coming together so far. It still has a long long way to go before its done, but I plan to be at the greer race come hell or high water
    els, Donald A. Smith, Butch M and 6 others like this.
  11. swade41
    swade41
    from Buffalo,NY
    Everything is looking great !
    els and volvobrynk like this.
  12. bigjohndsl
    bigjohndsl
    from Erwin, TN
    Looks Great!
    els likes this.
  13. tylercrawford
    tylercrawford
    from Buford, GA
    Coming along very nicely...can't wait to see it at greer
    els likes this.
  14. loudbang
    Wow a lot of progress there. You plan on anything non-slip to cover the pedals?
  15. jt306
    jt306
    Hay man glad to see you make so much progress. Quain was telling me about you and your build the other day. I run the 56 chevy 'Ol dirty *******'. Hopefully I'll make it to the first race in rockingham, still need to finish up a few changes from over the winter. Anyway keep pecking at, nothing beat the feeling of the first time down the track with a new car.
    els, volvobrynk and AHotRod like this.
  16. Dog_Patch
    Dog_Patch
    Looking good! We still have about 30 days. I think we can make it :rolleyes:
    els likes this.
  17. HOTRODPRIMER
    HOTRODPRIMER
    I love this car,,looks fantastic! HRP
    els likes this.
  18. sonic03bluegt
    sonic03bluegt
    from sc
    thanks for all of the kind words guys. Hoping to knock out the rest of the bodywork and prep and have it ready to paint on Tuesday afternoon. If the weather cooperates I will be painting it outside to keep with the low budget build. I've had some pretty good luck with outdoor paintjobs before in terms of finished product
    els, volvobrynk and no1nitrofreak like this.
  19. sonic03bluegt
    sonic03bluegt
    from sc
    the hood had previously had the bracing cut out before I got it so it was a big wave. Filler isn't thick in it but it took a while to block it out
  20. sonic03bluegt
    sonic03bluegt
    from sc
    fenders were pretty rough as well
  21. sonic03bluegt
    sonic03bluegt
    from sc
    Getting a lesson from quain on how to use the English wheel. Decklid was pretty rough so we spend a little time and got it a lot better before I started using filler
  22. sonic03bluegt
    sonic03bluegt
    from sc
    had to make patch panels on the door bottoms
    as you can see the door bottoms were pretty well gone
  23. sonic03bluegt
    sonic03bluegt
    from sc
    got the decklid fit on the car and figured out a way to only use one hood pin
    You can see the two retaining straps I made to hold the front of the decklid down
    els, Butch M and AHotRod like this.
  24. sonic03bluegt
    sonic03bluegt
    from sc
    More bodywork, the front of this fender was pretty bad, but I pulled it the best I could and got it decent
    rolled outside for a little shop cleanup
  25. sonic03bluegt
    sonic03bluegt
    from sc
    Did a lot more blocking on the front end, finally getting it close
    Made hood pin mounting points for the lower pins on the front end
  26. sonic03bluegt
    sonic03bluegt
    from sc
    ended up having to turn the rear lugs down so the would fit in the recesses on the rear wheels
  27. sonic03bluegt
    sonic03bluegt
    from sc
    Started getting my door alignment checked a body work started on doors as well
  28. sonic03bluegt
    sonic03bluegt
    from sc
    You can see just how pitted and rough the body really was in the next few pics. So far I have used over a gallon and a half of primer just trying to block all of the pits out
  29. sonic03bluegt
    sonic03bluegt
    from sc
    Last update for the day. Got the nose in primer finally! This bodywork has really kicked my *** and its the part I was looking forward to the most when I started, as it is where I have the most experience
    els, Donald A. Smith, Butch M and 2 others like this.
  30. AHotRod
    AHotRod
    Doing body work is a religious experience ..... just you and the Lord.
    Well done !
