Technical gas filler neck hose length
Discussion in 'The Hokey Ass Message Board' started by meezy, Mar 26, 2015.
  1. meezy
    meezy
    Howdy.
    Was wondering if anybody knows how long the gas filler neck hose ought to be for a 1950 Plymouth 2-door club coupe. Thanks!
  2. BJR
    BJR
    Crawl under it with a tape measure and you will know.
    wbrw32 likes this.
  3. meezy
    meezy
    there is no tank or hose at the moment...
  4. seb fontana
    seb fontana
    from ct
    Not even going to say put a tank in and measure...
  5. meezy
    meezy
    just wanted to see if anyone knew offhand. but thanks. i'll do that.
  6. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    4 feet should do ya
  7. timwhit
    timwhit
    Once you have everything mounted, go to O'reilys and buy a length of "gas filler neck hose" and cut it to fit. That's where I got mine.
  8. BJR
    BJR
    And don't use radiator hose even though it's way cheaper. The gas will eat it up and you will have a fire. Buy the real gas filler neck hose.
  9. meezy
    meezy
    Thanks for the useful replies, fellas.
  10. Mr48chev
    Most Napa stores will sell you gas filler hose by the inch. Others may too but I have bought it at Napa a number of times by the inch. You do need to know the id of the hose you want though as there are several sizes. I'm thinking you will probably need only somewhere between four and six inches of hose because you should have a steel filler neck up most of the way from the tank until it gets up close to the fender.
  11. manyolcars
    manyolcars
    theres probably a forum for that kind of car
  12. Mr48chev
  13. gimpyshotrods
    gimpyshotrods
    Yeah, this one.
