Technical No oil pressure on fresh rebuild....
Discussion in 'The Hokey Ass Message Board' started by Shaggy, Mar 16, 2015.
  1. models916
    models916
    Wow, looks like only about half you guys are reading all of this. You are replying to a solved problem.
  2. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Hey we just like to talk. Thanks for joining in.
  3. bobss396
    bobss396
    Success teaches us nothing. Chalk it up as a good learning experience and I think we all got something good out of it as well.
  4. Timbofor
    Timbofor
    That's a good way to think about it. I've made some dumb moves that cost me time and money that I wish I hadn't made. But live and learn. Now I know what not to do next time around.
  5. Shaggy
    Shaggy
    from Sultan, WA
    For anouther update, i broke it in today and put about 30 miles on it. It runs like a top, pulls like a SOB from speed and that M22 howl is music!!! On the other hand, i still need to burn off most of a tank of 87 octane, so i had to dump a couple bottles of octane booster in it so it wouldn't detonate while going into gear and still isnt happy. So on my way to work tomarrow i'll trade out the AC r45s's for a set of r43's and pull the 66 jets out and go some 68's. This weekend i'll look at timing too, i forget what the mallory YC distributer curved out at( i think it was close to early centrifical 'vette specs when i ran it on my machine), but it needs a hair less advance too, right now my inital is dialed down to 4 degrees to fix my "all in". Also i gotta replace that automatic ratio, i'm thinking 3.73's. It sure is fun having the baddest daily driver on the work commute again!!!
    40fordtudor likes this.
  6. Engine man
    Engine man
    from Wisconsin
    Pull the distributor out of a small block Chevy and you will see the oil holes. The oil galley for the lifters on the right side of the cam goes through the distributor hole.
