so everybody knows about the 1978 el camino rears. i was given some springs with my Buick that were claimed to be elky springs, but i think somebody was misinformed. anyways, i'm going to pick up some new rear elky springs from NAPA then that brings me to the front. my car came with NO springs in it, as it was a project car when purchased. otherwise i would try the t******* the stock springs approach that most with early 50's buicks use. after some research, i ended up installing some f-body moog springs part # 5662 but they just wouldn't compress enough to get the lower a-arms bolted back up. i tried using a spring compressor and a floor jack, but just couldn't get them in, so i cut a coil off after fighting with it for an hour. that was too much to cut off. the car is looooow. too low to really drive it around. i think i'm going to try a different moog springs. this site breaks down the differences in these springs nicely: http://jeffd.50megs.com/Moog_Spring_Page.htm i'm not sure which way i'm going yet, but considering trying the 5658 and see where she sits and then consider t******* 1/2 to 1 coil off if needed to get it down just right. what do yall experts think? before anybody says jamco, i can get these moogs' from amazon for just over $60 with free shipping.
I know nothing about El Caminos, are they all the same for 78? Are there variations? would the rear springs from any El Camino made in 78 fit a 58 Buick? I'm trying to drop the back on 58 Buick Special by 3"
hot4rods, Go to your local parts store. They should have a book with dimensions and you can compare the various springs. Or do a search here on HAMB, there have been a lot of discussions on Buick spring conversions.
I ordered some acdelco brand for a 1978 el camino. They're a progressive rate spring with pigtails. The car is on stands in the garage, hope to get the springs in this week. Will report back with pics and measurements and part numbers when done.
Oh, if only it were that simple. I live in the U.K, most of the few places that sell (imported) stuff for american cars are pretty useless and give little results when it comes to 58 Buicks.
Sorry that was my reply to fat47' but that's interesting to know regarding Amazon. Would these - http://www.opgi.com/el-camino/TRW6321/ be the correct springs to fit a 58 and lower it 3"? Just checked the springs on Amazon, they don't ship to the U.K. Will be very interested in the outcome of your springs when you've fitted them.
You could just get yourself some rubbers like they use on a roundy round and poke them in on top of the spring. They are cheap and easy to come by. That said if you can buy a spring that is perfect then go for it.
I should have time tomorrow to finish up the spring install. I was waiting for a fuel sender float (mine doesn't anymore) before I set the car back down off the jack stands but I'm getting impatient on that one.
Got the springs in finally! It has a nice tail draggin' stance right now. Needs skirts and lake pipes now. On the front it is about 15" from the center of the hub to the fender lip. On the back it is 5".
