I have for sale a 1953 Ford CrestlineVictoria, 50th Anniversary. This is very original including, 239 Flathead V8, 3-speed manual transmission with overdrive (3 on tree). Still on original 6v system. Runs strong and drives well. Has rust in quarters and rockers, needs paint, needs headliner, exterior chrome and stainless need re-done. Clean title. New Welded-in Floorpans, cut out and removed rust New Carpet New Seat Uphoshtery, new foam and, copied original pattern with pleats and two tone black and white. Looks sharp and feels great! New reproduction set of scuff plates. Needs headliner. Upgraded to Dual master cylinder for safety and reliability, new wheel cylinders, machined drums and new brake shoes all around, brake system is now better than when it rolled out of the factory. New inline brake light switch, new emergency brake cable Complete tune up including: spark plugs, dist. cap, rotor, points, condenser, oil and filter change, also cleaned out oil filter chamber, replaced leaky oil return tubing Rebuilt carburetor and new fuel filters Head gaskets replaced New wiper blades New battery terminals New single "glass pack" muffler for nice mild growl Replaced both water pumps (speedway) and upper radiator hoses Replaced ALL tires with radials (90% tread left) Brand New Bob Drake original replacement FUEL tank, and sending unit. 3" lowering blocks in rear Asking $7500 Call or Text Mike 303-859-7048 LINKS pictures on google https://plus.google.com/photos/101043475414462435911/albums/5998919906313548161 (copy and paste link) TAGS crestline, mainline, customline, victoria, sunliner, lead sled, rat rod, hot rod, flathead, vintage, traditional, old, custom, kustom, 2dr, business coupe, mercury monterey, lincoln capri, 1950, 1951, 1952, 1953, 1954, 1955, 50's, 1950's, 51, 52, 53, 54, 55
