Technical 48 Plymouth sway bar.
Discussion in 'The Hokey Ass Message Board' started by 48 PLYMOUTH HEMI, Mar 8, 2015.
  1. 48 PLYMOUTH HEMI
    48 PLYMOUTH HEMI
    from WV.
    I am trying to find information on which Jeep front sway bar will fit my 48 Plymouth coupe. It has 354 hemi, relocated shock mount, Cavalier rack and pinion and disc brake conversion, including the OEM "A" arms and stock spindles. I get a little more "dipping" in the turns than I think it should. Can anyone help? thanks.
  2. I used a late 90's on my 48
  3. 48 PLYMOUTH HEMI
    48 PLYMOUTH HEMI
    from WV.
    Thanks SCOTTY T. Any certain model and/or engine combination?
  4. It was a grand cherokee mid to late 90's I'll post pics in the morning
  5. 48 PLYMOUTH HEMI
    48 PLYMOUTH HEMI
    from WV.
    Thanks Scotty T, I'd really appreciate that.
  6. gimpyshotrods
    gimpyshotrods
    Jeep Cherokee, regular or Grand, 1", 1984-2001. Run it upside down.
  7. 48 PLYMOUTH HEMI
    48 PLYMOUTH HEMI
    from WV.
    You da man gimpyshotrods. Thanks, I'll go on the hunt tomorrow for parts.
  8. 48 PLYMOUTH HEMI
    48 PLYMOUTH HEMI
    from WV.
    Sway Bar 6.jpg Sway Bar 7.jpg Sway Bar 8.jpg Sway Bar 10.jpg Sway Bar 11.jpg I am posting photos of the sway bar and end links I am trying to install and with not too much success I might add. I got a 97 Jeep Cherokee sway bar and, as you can see, it appears to be too long on the ends that connect to the bottom control arms. This is a 48 Plymouth. I'm wondering if the before mentioned install was for a Dodge?
  9. gimpyshotrods
    gimpyshotrods
    You should be able to push it back a little. I have done this on a Plymouth.
  10. 48 PLYMOUTH HEMI
    48 PLYMOUTH HEMI
    from WV.
    Thanks gimpyshotrods, I'll try moving it forward enough to be able to make lower control arm brackets like you show in your photos. Thanks again. I'll post photos when I get this all finished.
  11. 48 PLYMOUTH HEMI
    48 PLYMOUTH HEMI
    from WV.
    Ok, I finally got started back on my 48 recently. I got the sway bar figured out, thanks to you Hambers. Now I am trying to finish the exhaust, air conditioning and wiring. I will post some photos, if I can, of my progress. Also notice in the photo how far away the tire comes from hitting the sway bar mount. This is with the rack lock to lock.
  12. n847
    n847
    Thanks for sharing. Im looking into doing this on mine. Did yours have the factory sway bar on it? If so did you notice improvement?
    Sent from my SM-N950U using The H.A.M.B. mobile app
