Projects Front engine dragster-Chassis Research 1958 -"Moon Rocket"
Discussion in 'Traditional Hot Rods' started by TheTumbleweeds, Jul 18, 2013.
  1. Tudor
    Tudor
    from GA
    Thank you and yes to save the head, probably won't p*** any rules or tech - I made some p***es without and if anything were to have happened it wouldn't have been be pretty. Still potentially safer than a motorcycle. I think it'll also allow much more use. A floor and helmet rest was also incorporated. It is very fun to drive. You've never felt anything like that under your right foot man. I dig your build as well. You are doing some great work. Nice work on adapting the coupler - that is nice and stout. Steering wheel looks great. Start saving for the driving suit :) That's another hole in the wallet. There will be lots of those lol
    TheTumbleweeds likes this.
  2. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Yeah those holes are many.. :-S
    Its realy exciting to run the very first run I hope :)
    I checked out every pic you had in your albums! So cooool
    Tudor likes this.
  3. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    DSC_2711.jpg my skin hurts on my thumb.. But now, done! :)
    Tudor likes this.
  4. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    DSC_2714.jpg the gauges got some polishwork too ;-)
  5. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    DSC_2720.jpg the steering box needed some New grease and recheck play. Anyone knows the fab?
  6. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Anyone knows the fabricator of this unit?
    well its in Good condition, need no rebuild, just some new grease and adjusting. Can't wait to put it together :) DSC_2721.jpg
  7. Nobey
    Nobey
    These are 35 ford drums with the ribs. Rich
  8. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Thanks man!
  9. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    After this picture, the housing is repolished and the screwaxle where checked up. And the main axle with bearings are put together. Screenshot_2015-02-19-18-42-40.png
  10. TheTumbleweeds
    TheTumbleweeds
    from Sweden
  11. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    A small update, but, I made a bar between front Wheels, just need some paint in the ends, and polishing. DSC_2933.jpg
  12. dragsled
    dragsled
    from Panama IA
    Doing anything on the ch***is yet?
  13. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Not realy, has been some work on the rearEnd, and steeringparts..
    But Im workin on some weld on brackets for the axles. Need to fit those permenent, to build ****pit.
  14. TheTumbleweeds
    TheTumbleweeds
    from Sweden
  15. TheTumbleweeds
    TheTumbleweeds
    from Sweden
  16. saltflats
    saltflats
    from Missouri
    That's some super detail there Tumblweed
  17. dreracecar
    dreracecar
    from so-cal
    Warning--- If you have to or plan on running the spindle ty-rod foward you will have major steering issues where as the out-side wheel in the turn radious will pinch off and scrub. Move the ty-rod arm to get the ty-rod end as close to the wheel rim as you can safely. Many threads here that go thru the AKERMAN princple of steering-- in a sense a straight line from the center of the rear end thru the center of the front axle spindle center-line and the center of the ty-rod end. At minimum the placement of the ty-rod end should be 90* to the spindle axle using the kingpin center as the common point..
    TheTumbleweeds and loudbang like this.
  18. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Thanks man!!! :)
  19. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    There was some realy interesting Reading on this ackerman! Maybe its not that big issue on a dragster? I mean it suppose go straight ahead.. But yeah, you have a realy good point there
  20. Tudor
    Tudor
    from GA
  21. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Funny thing, same issue, same time :)
    I realy need to check it up
  22. roseville carl
    roseville carl
    Your attention to detail is great........ can't wait to hear her lite up and make a p***
  23. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    I found two axles for my old banjo :)
    just need to cut down to right length, and make the right Splines.
    now I need to buy a spool, then we have e real beefed up rear end DSC_3058.jpg
    volvobrynk likes this.
  24. dreracecar
    dreracecar
    from so-cal
    buy the spool first and fit the axles to the spool
  25. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Of course, so it comes in the right order :)
  26. dragsled
    dragsled
    from Panama IA
    Some companys have differant spline cut , Mark Williams have there own spline cut , Their axles fit their spools only
  27. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Here is the difference between the axles
    A little bit safer this way, and the right one is famous to hold the strength. DSC_3110.jpg
  28. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Yeah, I tried that one on my Ford 9 , with 35 splined MW spool
  29. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Now the endings are cut off and goin. For some machining before they are going to be welded on the old banjo axle. DSC_3118.jpg
  30. TheTumbleweeds
    TheTumbleweeds
    from Sweden
