Hey guys, I'm running a Hilborn stack injection setup on my 55 Chevy with 12" ram tubes. My front end is all original steel and I really didn't want to use any fibergl***. I have a near perfect hood that I planned on cutting so the ram tubes will stick out of it. I brought it to a guy who is helping with some other fabrication on the car. He said he could cut and properly brace the hood so I can still use the hinges. I dont want a lift off hood. I called him tonight and he said "are you sure you want to cut this hood, it's so nice" Now he has me feeling guilty about it. I know it's my car and my decision, but now I feel bad. What do you all think??
see if you can find another hood, Ive had 4 different hoods on my truck, one with a scoop, one peaked, the stock one, and now one with a hole cut in it with a chrome scoop sticking through
What better to cut up then a " perfectly good hood " I Wouldn't waste my time cutting up a bent up rusty one ...... of course I punch holes in Perfectly good hoods all the time! And it make them "perfectly better hoods " I Say cut it !!!! "Cut ME MICK"
A fibergl*** hood is traditional on a car like you are building. It's been used in (race) cars since before your car was built.
Well Shackey, I've been in this spot before, whacked a cherry hood then after a while went back to the original setup. I'd find another hood my 2c.
How far are you in the build? Is the hood the next step, or will it hold you up from moving forward? There are a ton of hoods out there that have been cut already. Give it a while and search for one. If you find a good candidate, you're set. If you can't, then at least you tried and will have a clear mind about it when you cut the hole in your good one. -Brad
The car is probably making it's maiden voyage to the track in 2 weeks. I can run without a hood since I dont run a mechanical fan. I do have another rough hood, but it will require that much more body work to get ready for paint. Maybe I will hold off for a while.
who's to say your new hood wont end up as bad or worse than the bad hood when the hole gets cut into it? I would waste my time on the bad one so that you dont end up with 2 bad ones! Just my 2 cents. .
That's exactly the kinda car that 'gl*** is made for. When I was in high school in the 60's and running tri-5's, gl*** frontends were the hot setup. I agree with DrJ...keep the cherry tin and go gl***!
I agree with using 'gl***. Not that I'm agianst cutting old stuff up, but that car needs some fibergl***... If you don't mind me asking, Shakypudding, what do you have against fibergl***? More importanly, race weight 'gl***? BTW...I love that car, I have a few pics of it here in my studio, for inspiration.
you can buy a gl*** one from VFN in street weight and use your hinges and no springs or light ones??? that is what is on the black magic 55..........looking good by the way.. like the injection on it.........
I have nothing against fibergl*** and I know how popular gl*** fronts were on the old g***ers, but I've got lots of nice front end sheetmetal. If mine were rusted or needed work, and I had to start from scratch, I'd probably consider gl***. I would probably consider a gl*** hood but my motor is set so far back, I have to cut the back of the hood also, so it would end up U shaped. I wouldn't think a gl*** hood would retain it's strength. I'd be afraid I'd crack it even with the springs removed from the hinges.
I ran into this same problem last year - I solved it by grabbing another hood and sticking it in the attic. By still having a "good" hood - I didn't have any guilt when I wacked mine. Of course mine was for a lowly Rambler, but they arn't always easy to find in nice shape either.
Quote: Originally Posted by Nads Well you know I once said I'd never **** man-**** for a quart of Colt 45, but I did. So what's your point? **** confucious I think this is the best quote i have ever heard.
or a diamond in a goats *** you still got a goat== cut the bad one see what a big hole it has to clear with hinges n you will save the good one been there n done that 2 cents worth Kenagain newby now no more fng
I've got a pretty nice 55 hood that had a teardrop scoop gl***ed to it. It's got a bunch of 1/8" holes drilled in it for the pop rivets the guy used to keep the scoop on. You can have it CHEAP!
Amen.... Let the guys who like to throw money at stuff have the ****ty stuff so they can have there "before and after "shots laying out at the car shows!
If ya' gotta brace the cut out opening anyway,(as the opening comes from the trailing edge of the hood,i.e. eng. setback),I would go with whatever material you or the person doing the cutting and bracing is comfy with. If your metal hood is that nice,keep it ,or sell it for major bucks to finance another portion of your build. you are gonna' get numerous different opinions here on which hood to use. you are the only one who has to live with which type,and condition ,of hood you whack up. what does your gut feeling tell you? I would cut either without hesitation! Don't be scared,young man!
You had no problems cutting up the car, so why the issue with the hood? If it isn't going to take a hundred years, do as was suggested and find a hood with a hole in it. If you can't, screw it. Make that hood yours. nocoastsaint
