Hot Rods Sbc fuel pump with 3 connections ?
Discussion in 'The Hokey Ass Message Board' started by olds vroom, Apr 6, 2015.
  1. olds vroom
    olds vroom
    I have a sbc 305 and the fuel pump has 3 connections I've never seen this before what is the third connection for? Can I cap it?
  2. Someone mentioned fuel tank vent, it is part of the clean air stuff and not at all necessary for the operation of your car.
  3. bonzo-1
    bonzo-1
    The extra line usually goes to a canister to collect vapors. Emission stuff.
  4. GMBOWTYE
    GMBOWTYE
    from Ames IA
    The third line is return line back to tank.It was to help cure vapor locking . I have block them off
    tb33anda3rd likes this.
  5. GMBOWTYE
    GMBOWTYE
    from Ames IA
    Its the smaller line
  6. squirrel
    The third line is not a vent, it's the return line to the tank. Helps with vapor lock issues, if you can run the line to the tank, then do it. Or get a two fitting pump instead, if you don't want the return line. They only cost $20. and you didn't want to put an old used pump on your car anyways.
  7. woodiewagon46
    woodiewagon46
    from New York
    Yes it is a return. Some years ago when we had a fuel shortage, I had a van and I installed a second fuel tank with a three way valve. Only the stock tank had a gauge, so when I ran on the second tank, the fuel gauge would actually rise when I drove because of the return.
